Question about Cell Phones
Samsung g2 wont charge and high voltage alert pops up after awhile
  • 327 Answers
Use original charger
Posted on Jan 04, 2014
Tela escura
Google for the service manual, should be available online for free, the G2 voltage should come from the D board where the high voltage circuit is.
Dec 14, 2012 | Sony KP-57WV600 57" Rear Projection...
How and where can i locate the g2 high voltage to the blue tube on a 65" mitstubishi HDTV model WS-65511 serial :118393 so i can adjust it ????
g2 is also known as screen voltage. the adjustmen knobs are located on the high voltage block behind the front panel. its a black square bloc with 6 adjustment knobs ussally label focus and kscreen one for each and one for each tube. WARNING ADJUSTMENT OF THESE can be tricky and inpoperly set will cause shutdown of set.
Oct 16, 2010 | Mitsubishi WS-65511 65" Rear Projection...
My tv wont turn on the light on the power button blinks and the lamp turns on in the back but the screen dont light up
check if crt screen voltage correct (g2) try to adjust screen settings at flyback transformer and monitor if g2 response, some model if vertical ckt down monitor have black signal only can determine if screen adjustment knob in flyback transformer turn increase. vertical line appear.
Mar 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung Model HLR4667WAX/XAA is making a buzzing sound
This TV is horrible. I have the same one and not even a year replaced the light bulb twice. Very disappointing for a Samsung.
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
WONT TURN ON
you need batteries with a high voltage...combined over 3.3
Feb 02, 2009 | Samsung S860 Digital Camera
I paid 9.95 for assistance and did not get a responce but charged
From your description it sounds like G2 voltage on the green picture tube is too high.
Are you confident about adjusting it yourself? There are high voltages in places which can kill. I will not take any responsibility of you getting an electric shock so I suggest calling in a qualified TV technician.
Any TV technician should be able adjust this voltage and it should not take long to do it unless the cases are hard to remove and hard to access the flyback transformer where the G2 (screen) adjustment is located.
Otherwise it may be a faulty green picture tube and this is expensive as you need to get the tube replaced.
Hope this helps
Nov 21, 2008 | Televison & Video
Brighten my computer
1.Check G2 Screen Cathode Voltage.
2.check from G2 cathode to LOT G2 supply pin It's related Low value &High value resisters.
3. replace G2 PF
Sep 22, 2008 | LG Flatron F900P 19" CRT Monitor
SyncMaster 753s G2 voltage.
Dont worry chayan ghosh +500 is the correct voltage
Take Care
Bye
Apr 01, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Brighteness
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus. I spend 30 minutes popping the case apart just to find that I could not access the adjustment screws from inside. Lo and behold, they made them easily accessible from the outside. On a side note, I have never seen a TV designed as poorly as this on the inside. You have to literally reach in and unplug things just to get the back off. All the electronics save the tube itself are mounted to the rear chassis. On all other TV's I've seen (taken apart, rather), all the electronics are in the FRONT part of the chassis so that they move WITH the tube.
Sep 23, 2006 | JVC AV-27530 27" TV
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
