Question about Vehicle Parts & Accessories
Why does my break lights come on automatically, and I have to go out (press and release pedal to turn them off)problems avital
My wife came into the living room last night and saw the break lights on like some one was pressing the pedal. this morning I got up, and they was off. I turned on the fireplace and tv. later I noticed the break lights on. will my household remotes do this? if not whats doing it?
    Top Expert:
  • 37,979 Answers
A defective stoplight (brakelight) switch could be the cause.
Posted on Jan 03, 2014
3 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 34 Answers
SOURCE: im about to install a
the one you need to use is the wire that shows a 12volt power in cranking posision
Posted on Jan 09, 2009
SOURCE: I need to program a new remote for a python 460HP.
i bought a remote on ebay and im try to program it its a python 474p
Posted on Aug 21, 2011
1994 Ford Escort,will not go into gear(automatic), turn signals wont work, warning lights don't light up when cranking.
Start with checking the brake light switch.
follow the brake pedal up the metal arm until you see a little switch pressed against the metal arm.
When the brakes are pressed, the switch button extends and unlocks the shift lever and turns on the brake lights.
It is common for a little plastic piece to deteriorate and break away, causing the brake lights to stay on and can damage the shift lock solenoid.
Attached is a photo of the brake switch where it contacts the pedal arm.
There is a little snap cover beside the shifter. You can pry it open with a little flathead screwdriver and insert a thin object inside to release the shift lock and get out of gear until you find the fix.
Nov 30, 2016 | 1994 Ford Escort
Need instruction for programing avital 473L
Turn the ignition on, press and release the valet switch then press and hold the valet switch. Press the lock button on the remote.
Feb 26, 2014 | Avital 4111 Remote Start System -
Need to program additional fob to Avistart 4111
Turn ignition on, press and release valet switch then, press and hold valet switch. Press button on remote. Release valet switch, turn off ignition. Test
Feb 08, 2014 | 4111 4111L Remote Car Starter
Remote starter problems avital
If your brake lights come on you could have a sticky brake switch!
Try to spray it with WD40!
Jan 03, 2014 | Vehicle Parts & Accessories
My break lights wont turn on when I press my breaks. The fuses are all good. I changed the bulbs and still no light. What else could be the problem?
Most likely the switch that is activated by the brake pedal has come loose or needs to be replaced. It is mounted on a stationary bracket and is activated as the pedal either presses against it or releases it depending on what they choose to use that year.
Jul 22, 2011 | 1999 Chevrolet Suburban
My break light swithes on sometimes without me even pressing the breaks. The break light also sometimes stays on even when I have taken my feet off the break. I have tried changed the break light switch...
Did you adjust the brake light switch correctly? To adjust the brake light switch, first press the brake pedal down a few inches, then pull the switch plunger rod out of the switch toward the brake pedal arm, as far as you can without using excessive force. Next, return the brake pedal to the pedal stop position against the pedal stop and pull the brake pedal toward the rear to push the brake light switch actuating plunger rod into the switch housing limited by the travel of the brake pedal arm rear travel stop position. This procedure automatically adjusts the brake light switch correctly.
If the brake lights still don't turn off with the brake pedal released, check the brake pedal arm for sticking or binding that is preventing the brake pedal arm from returning fully to the pedal stop when the brake is released.
Feb 21, 2011 | 2002 Audi A4
Right and left brake lights not working...centre light is fine....bulbs look ok any other fault to check?
I would say it is your break switch. It is located under the dash and the break pedal actually hits it. It look chrome and it is a round cylinder. It has a button on it. When you press the pedal down, the button releases, therfore, it turns on your break lights. If the fuse is ok and the bulbs aer ok, this is your problem. Thank you very much for choosing FixYa. Good evening.
Feb 19, 2011 | 2004 Mazda MX-5 Miata
My break light wont turn off
Check the switch at the back of the brake pedal, they can come out of the housing. Some are threaded in some are just a quarter turn to release. Press the switch manually and see if your lights go off, if they do re-adjust the switch Should be pressed in when pedal is released.
Feb 04, 2011 | 1997 Cadillac DeVille
I need to program a second avital keylees 3 boton remote in order to have one for me and one for my wife
Turn ignition on, press and release programming switch once. Press and hold programming switch, press and release lock button on new remote. release programming switch.turn off ignition , test.
Sep 26, 2010 | Car Audio & Video
My Avital 477L remote got wet. It is dry and working fine, all the lights come on. However it doesn't work with my car anymore. Is there a way I can reprogram it.
Open door, turn ignition on, press and release programming switch one time, press and hold programming switch while pressing lock button on remote. You should hear a confirmation chirp from unit.
Sep 25, 2010 | 477L Ask RXTX HHU Remote
Vehicle Parts & Accessories Logo
21 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
