Copal DPB-6000 paper transport
How can i fix error of E550 toshiba 230 e studio.?
E550 is paper remaining on the transport path...
U need to see where the paper stop...
If no paper, u need to check all the sensor such as registration, 1st transport, 2nd transport, exit, ADU...
Jun 25, 2017 | Toshiba Office Equipment & Supplies
Error 6000 Canon Pixma MX925 need help. I've tried unplugging, on-off etc, and nothing so far gets rid of the error message. Any suggestions??
I had this problem it turned out to be a paper jam I could see it sitting under the front rollers behind the ink cartridge transport.
I removed the back panel and then the transport cover exposing the paper. I then gently removed the paper. That sorted it no problems. PIXMA MG7520 Removing jammed paper cassette 1 automatic double sided...
Oct 01, 2013 | Canon PIXMA MP150 All-In-One InkJet...
Service error 6000. Cartridges won't slide to the left
4. PRINTER TRANSPORTATION
This section describes the procedures for transporting the printer for returning after repair, etc.
1) In the service mode, press the Power button to finish the mode, and confirm that the paper lifting plate of the sheet feeder unit is raised.
2) Keep the print head and ink tanks installed in the carriage.
[See Caution 1 below.]
3) Turn off the printer to securely lock the carriage in the home position. (When the printer is turned off, the carriage is automatically locked in place.)
[See Caution 2 below.]
4) To further secure the carriage to prevent movement from the home position during transportation, make and use a fixing tool in the following procedures:
i. Fold an A4-sized paper 5 times, and wrap it twice with tape, as shown in Figure A below (to prevent the fixing tool from caught into the inside of the
printer).
ii. Insert the fixing tool between the carriage and the main case unit, and securely fix it with tape, as shown in Figures B and C below.
Note: The tape should be similar to the polyester tape used at shipment, which will not easily be torn or removed, or leave adhesive on the unit when
removed.
Leave a sufficient length of tape to fix the tool so that the tape end is easily seen even when the cover is closed, so that the user will remove the
Aug 23, 2011 | Canon Pixma iP6210D InkJet Photo Printer
Paper jam to the right before printing starts
your paper must be jamming because your are not putting paper properly in the printer
Apr 01, 2011 | Canon PIXMA MX340 Wireless Office...
Error message 6000
6000 is a paper jam or jammed sensor.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Click service and support, then enter error 6000, then click Error LCD ... 6000..., then click Removing paper jams mp600. Sorry, but they use javascript so I can't give you a more direct link.
Sep 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Mx 850 canon with reoccurring error of 6010 or 6000
if it's 6A00 then theres a problem with the cleaning unit where the printhead parks. Look for any paper scraps in that area, 6000 is a paper feed error saying something may have fallen in stopping the paper transport roller.
Jul 23, 2009 | Canon PIXMA MX850 Multifunction Printer
Kyocera FS 9130DN is showing MP tray transport jam and to open front cover. No paper is jammed or in the machine.
check the bypass transport connector for a small piece of paper. or the paper sensor arm is jammed down there are 2 one in the transport unit and one in the mp tray
Nov 03, 2008 | Kyocera Office Equipment & Supplies
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
jasbo
jasbo
