Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Error code C-0211 Konica Minolta Bizhub C-351
I have this error code wanted to know the master reset or if someone can tell me what the problem is
  • Ignacio  Montero
    Ignacio Montero May 22, 2009
    I figured it out thank you. I will post
I have a Konica bizhub c351 with and error code of c0211. I took the back off and played with the black motor that lifts the tray. The tray moves freely and the motor seems to move freely. When I turn the machine on it does not go through any kind of check like it did before it just goes to the same screen. Is there a way to reset this to get it going again to test if there is still a problem
Posted on Nov 03, 2009
It's called "Manual Bypass paper lifting failure". The manual says to check Tray 2 vertical transport motor. Check the wires to see if the are okay. Pull out tray 2, remove back cover, remove wire assembly from 4 wire saddles, remove 2 screws and the motor assembly. The should be 2 motors on the assembly and the one u need to look at is the bottom one. hope this helps.
Posted on Aug 04, 2009
Testimonial: "Great tech"
  • irfanfard Aug 16, 2011
    i have solved the problem.. iam technisian on indonesia.. its because paper lift in the by pass failure... i check the two motor( magnetic and sping) its ok.. and i i check the selenoid ( this is the problem ) but when i replace the selenoid with the new one, the problem not solved... so chek the PRCB ( pcb in the back left , close with power suply) i see the Tr7 is damage, so i replace the PRCB and then the problem is solved..
I HAVE FORGOTTEN MY SECURITY CODE.
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Nov 17, 2008 | Nokia 6288 Cellular Phone
Whirlpool duet washer code
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Resetting Security Code
master code for imei  355397009002339 is  3537356212.
After unlocking it goto security option.Now it will ask you for the password so enter 3537356212.And after entering this no it will ask you for a  new password..that's it enter new password for 2 times and you are done.
Sep 05, 2008 | Nokia 1100
You can always contact Nokia. They will tell you the master reset code, but it will erase all of your current info.
Jul 09, 2008 | Nokia 5300 Grey Cellular Phone
format ur phone with u.f.s software with computer
Mar 31, 2008 | Nokia 6103 Cellular Phone
i have nokia 1112
my imei no is 354573018881860 i want to reset my code
Mar 04, 2008 | Nokia 1112 Cellular Phone
Model : Nokia 6300
IMEI : 359809013573044
Can you please tell unlock code?
Nov 09, 2007 | Nokia 1600 Cellular Phone
maybe you phone isnt dule band if you get the security code wrong 5 times it will then ask you for master code but if your phone is locked to one network try trycktil.com these will tell you how to unlock your phone to any network provider they will tell you how to do it step by step hope this is some help................
Nov 02, 2007 | Nokia 1600 Cellular Phone
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
1,813 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
