Question about Vehicle Parts & Accessories
Remote starter problems avital
Why are my break lights coming on automatically? it kills the system, and you have to go out and press and release the pedal to turn them off.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
If your brake lights come on you could have a sticky brake switch!
Try to spray it with WD40!
Posted on Apr 30, 2014
jpk528
  • 95 Answers
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Posted on Mar 03, 2009
  • 171 Answers
SOURCE: AVITAL 4103 REMOTE STARTER STARTS BY ITS SELF
Check the alarm program it shoudl be programing to turns it On every 2 hours, or if you have a temperature sensor should be programed to turns it On when is too cold.
Posted on Jan 05, 2010
logosc75
  • 625 Answers
SOURCE: can an avital 4113 remote starter be installed in
Yes, just program the wait to start to 15 seconds.
Posted on Sep 16, 2010
SOURCE: my avital 4113 car remote
DEI sent out a recall on a batch of theit antennas for this sysetm that were remote starting the car by its self. If you call customer service they will send you a replacement antenna and this sould fix your problem.
Posted on Jan 26, 2011
logosc75
  • 625 Answers
SOURCE: i have a problem with
If this is the factory alarm going off when you remote start the vehicle, the factory disarm wire is not connected. If you would list the year/make/model of the vehicle, I could direct you to the wire.
Posted on Feb 25, 2011
2002 cavalier, ignition cylinder was changed for pass lock failure now remote start cranks but wont start. avital 4103L
Hi, ur problem is a simple one. U have a factory alarm-starter kill. The key and ecm have to comunicate. Ur alarm has a digital modual to make the ecm think its seeing the key when u remote start. Since u changed the "code"u have to reprogram your alarm interphase so it all comunicates the code.
Nov 28, 2015 | 4103LX Remote Start System with Two...
How can I get instrction book for reprograming avital remote starter for rpn 7111l
If you are looking to sync the remote key fob to the remote starter:
Remote programming 1. Turn key to the ON position 2. Within 5 seconds, press and release Valet button one time. 3. Within 5 seconds, press and hold the Valet button. The LED will flash one time and the horn honks to confirm entry into remote programming. 4. Press the button on the remote control. 5. The horn honks to confirm the remote has been programmed. 6. Release the Valet button, and turn the key to the Off position. 7. The horn sounds one long honk to confirm that remote programming has been exited. The programming routine exits if any of the following occurs: • The ignition is turned off • There is no activity for 30 seconds • The Valet button is pressed too many times
Mar 01, 2015 | Avital Vehicle Parts & Accessories
I had a avital remote start pot on a 2004 chevy venture van. everything worked ok for a month then the remote locks, poer windows and dome lights quit working. are they all connected together for the...
Avital is one brand of remote starter that features easy-to-use keyless remotes. These remotes can be programmed wirelessly to your engine and then added to your keychain. Once programmed, you will be able to use the remote from as far as a couple hundred feet away in your house, the street or a parking lot. If your remote is not working, you can troubleshoot the remote and get it resynced in seconds.
  • Enter your caricon1.png, leave your driver's door open and insert your key into the ignition.
  • 2 Turn the ignition to the "On" position and press and release the "Valet" button on your remote.
  • Press and hold the "Valet" switch again after releasing the first time and wait for the system's siren to chirp and the LED lighticon1.png to blink.
  • 4 Continue holding the "Valet" button and then press the starter button on your remote.
  • 5 Wait for another chirp and release both buttons to complete the process.
  • Apr 08, 2014 | Cars & Trucks
    Need to program additional fob to Avistart 4111
    Turn ignition on, press and release valet switch then, press and hold valet switch. Press button on remote. Release valet switch, turn off ignition. Test
    Feb 08, 2014 | 4111 4111L Remote Car Starter
    Avital 5303 kills engine while driving 1998 honda civic
    you check to see if the engine was hot or something like if the water level in the radiator was down the sensors in the security system would pick it up
    Jan 27, 2014 | 5303L 2Way LCD Remote Start Security...
    How do I activate the alarm on my Dodge
    The 4103 is not an alarm. It's a remote starter with keyless entry! Do you want the horn to sound when locking and unlocking? First, make sure that the horn wire was connected. Press and hold the lock button on the remote. That should activate the panic/car finder. The horn will begin to sound. Press and release the lock button to turn it off.
    If the horn is connected and, you want said horn to sound when locking and unlocking, open door, turn ignition on then off, press and hold programming switch until the horn chirps once. Release programming button, press and release programming one time then, press and hold programming button. While holding the programming button press and release unlock button on remote. You should hear two chirps from the unit. Release programming button, turn ignition on to exit programming, Test system.
    Feb 13, 2013 | 4103LX Remote Start System with Two...
    I lost my remote start key flob ,Avital 4113 ,so I ordered a new one from Best Buy and it comes with some instructions ,but they are not clear to me about how to get the system to accept new remote start...
    Open door, turn ignition on, then off. Press and release programming switch once, then press and hold. Now press and release button on remote. Release programming switch. Remove key, test remote. Afterwards, repeat for second remote.
    May 21, 2011 | 4113LX 1Button Remote Start System with...
    Both remotes failed to either start the car or lock or unlock the car this evening.. after entering with the key the old fashioned way, the car will not start with the key,the starter turns over fine...
    no reset button, sorry. If the starter is turning over, then it's more than likely not an alarm or keyless problem. if it was even connected, the starter kill feature is used to "cut" the starter wire from the ignition and the starter itself, and if you say it's turning over, that's where i get my answer for it not being the avital. of course there could be more to it, remote start added, and the type of car make a huge difference, could be a bypass module for bypassing a factory security system, so without any more info, that's all i can give you. hope this helps, dave
    Nov 10, 2010 | 2101L Keyless Entry
    My Avital 477L remote got wet. It is dry and working fine, all the lights come on. However it doesn't work with my car anymore. Is there a way I can reprogram it.
    Open door, turn ignition on, press and release programming switch one time, press and hold programming switch while pressing lock button on remote. You should hear a confirmation chirp from unit.
    Sep 25, 2010 | 477L Ask RXTX HHU Remote
    Vehicle Parts & Accessories Logo
    32 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
