Question about Polar F6 Wrist Watch
Inaccurate Measurements of heart rate
My polar watch was acting erratic when displaying my heart rate. For example, when I ran on the treadmill it said 90bpm and then it jumped all the way to 210 bpm. After I got off the treadmill, the watch was stuck on 210bpm for at least 15 minutes, even though my heart rate had been lower than 210bpm for at least 10 minutes. How do I get the watch to read my heart rate more accurately without it jumping around from very low to very high numbers and getting stuck on numbers?
    President:
  • 1,902 Answers
Replace the battery. Then make sure that it is placed on the proper artery that it is supposed to be on. If your heart rate was 210 you would be in the hospital with a heart attack. And also the only person I know with a heart rate of 90 when running is Lance Armstrong. Your heart rate should be about 120 to 135 and it will just around in those areas but should never go higher
Posted on May 22, 2009
Under the settings, limits, the limits on the max HR stop @ 100. I want to increase the setting on max hr but it stops @ 100 and then returns to 18. help [polar F4]
Go into settings.
Press the center button on the right hand side of the watch 1 time you will see settings watch time & date appear in the display.
Press the bottom button on the right side of the watch1 time to get into the TRAINING SETTINGS FUNCTION.
When you see TRAINING SETTINGS in the display press the center button on the right side of the watch once.
You are in TRAINING SETTING mode.
Press the bottm button on the right hand side of the watch 3 times until you see
ZONE LIMITS displayed.
When you see ZONE LIMITS displayed press the center button on the right side of the watch 1 time to enter into the ZONE LIMITS FUNCTION.
Now, you should see the lower end heart rate limit number blinking.
To adjust this number use the top button on the right hand side of the watch to increase this limit or lower button on the right hand side to decrese it.
When you have it set where you want it press the center button 1 time to save that setting.
Now you should see the upper limit number blinking.
Follow the same steps to set the upper heart rate limit.
When you have pressed the ceter button to set the upper limit you have completed setting the heart rates limits and the display should read: LIMITS SET!
Feb 13, 2011 | Polar F4 Heart Rate Monitor Watch
The battery was flat. renewed it and all working EXCEPT it no longer can pick up heart rate from monitor (tried it with another monitor and still will not pick up heart beat) Help Please...about...
i guess stopped of use your strap for a long period of time. so you need to nicely clean the strap and try a lot of times until it work again.
I happend to me before and the strap worked only after the 10th session on the treadmill
Feb 11, 2011 | Polar FT60 Heart Rate Monitor (Purple)...
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
Changed the battery and now it won't pick up the heart rate monitor. I know the monitor works because it is picked up by all the equipment in the gym.
If Heart Rate is being displayed on the equipment in the gym, but not your watch, then your chest strap is transmitting fine, but the watch is not recieving the signal.
It is not uncommon that when a battery is changed outside of a polar authorized service center that something can happen to the internal electronics. I would suggest you send the watch into Polar and have them take a look. if you have had the watch less than 2 years they will most likely take it under warranty and correct the issue, at the very least they have equipment to test and diagnose both the watch and strap, although it sounds like your HR strap is fine since you are getting HR on the machines.
Dec 27, 2010 | Polar FT40 Heart Rate Monitor Watch
I just put a new battery in the Polar F4 heart rate monitor watch and it does not work. The battery died about 2 years ago and I never replaced it until now. How can I get the heart rate monitor working...
This is a common issue. The Polars and other Heart Rate monitors are not designed to be fixed by the consumers except for very specific models. These only look like watches, they are in fact mini computers and very susceptible to internal damage if not handled properly.
You need to send the unit it to a Polar Authorized Service Center to have fixed properly. There is not reset within the computer, if you had done everything correctly then it would work.
Dec 12, 2010 | Polar F4 Heart Rate Monitor Watch
I changed the battery in the f6 . I had erratic readings. Now watch seems fine but it wont read heart rate,,,,I get no heart beat at all .
Check out my tips and tricks section for a guide on troubleshooting heart rate readings.
One other possibility if you changed the battery yourself (never recommended) is that some damage or moisture has gotten into your watch and made it impossible for the watch to read heart rate. This is a more common reason than you think and why all manufactures of Heart Rate monitors and other types of watches have you send them in to their authorized service centers.
Dec 08, 2010 | Polar F6 Wrist Watch
Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
Aug 02, 2008 | Polar F6 Wrist Watch
Polar f11
no it shouldnt be cause the heart rate would be based off your pulse
im not a heart specialist but ive had my share of heart polups and a faulty valve in my heart
i was told by my doctor that the heart rate is monitored by bloodpreasure threw the veins pulse so i dont think that the size of the watch would make a difference this is in my opinion based off my own docs words hes the doc what can i say
but recommend that you speak with your doctor about heart monitor watches they know more indepth about these devices or your local pharmacy
i hope this helped you out
Jun 05, 2008 | Polar F6 Wrist Watch
Polar F6 Wrist Watch Logo
482 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
