Question about Garden
I need to change the blade belt on my troy bilt 33 inch walk behind mower
Change the blade belt
    Problem Solver:
  • 6 Answers
Look up on the internet the make and model of your mower and look under diagrams
Posted on May 22, 2009
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
I have a 42 inch troy-bilt riding mower the blades won't disengage.
Sounds like either the switch for the blades is not shutting off the power to the electric clutch or the clutch itself is not disengaging. I would shut the mower off and unplug the wire to the electric clutch and then start the mower and make sure the blades do not turn you may have the belt for the blades on the wrong pulley and it might be causing the blades to turn. Hope this helps.
Apr 18, 2014 | Troy -Bilt String Trimmer/Blower...
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
How do you put a mulching blade on a troy bilt 21 inch walk behind lawn mower
remove the center bolt from under the machine put a block of wood against the blade to hold it from turning on you
Apr 13, 2012 | Garden
HOW DO YOU PUT A DRIVE BELT ON A TROY BILT 33"
I think you should go to your local dealer. They will be able to pull up the info you need and they may even print up for you a picture of the way the belt is installed. GOOD LUCK.
Jul 03, 2011 | Troy Garden
33 inch Troy-Bilt walk-behind clicks while trying to elect start
Check the voltage to the solenoid when the key is turned to start, it should be 8-12 volts. IF the voltage is low clean all electrical connections.
Jul 06, 2009 | Garden
Troy bilt mower self propelled 21". Belt has come off
Take the three screws out of the belt cover. One screw in behind each back wheel. The other is under the mower near the shaft to blade. Remove the tension spring off the transmission. Then remove blade and the cover comes off. You then can put the belt back on. Sounds like fun don't it!
Jun 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Ineed the diagram for a 42 inch deck troy bilt
We I disengage the blade belt always comes off its to loose I have had the number checked they say its the right belt but its so sloppy
Apr 26, 2009 | Garden
Garden Logo
500 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
