Question about Zanussi FJS1225W Front Load Washer
Washing machines Belt replacemnt
    Prodigy:
    An expert who has answered 500 questions.
  • Zanussi Expert
  • 517 Answers
If it is broken ask yourself ' WHY' it is broken
was it loud in spin
if so bearings are going
don't buy the belt
it's a big job ????
Posted on Jan 30, 2014
Whats tricky about the remover and replacement?
How to Replace a Washing Machine Belt: 12 Steps (with ...
www.wikihow.com > ... > Washing Machines and Dryers
wikiHowLearning how to replace a washing machine belt can be tricky, but will save you from.... specifics of the location and method for removing and replacing the drive belt. ...your washing machine, then your model has what is called a direct drive.
How to Clean a Washing Machine Inlet Screen ' The Family ...
www.familyhandyman.com/...repair/washer...repair/...washing-machine...
A washing machine that takes forever to fill may have an inlet screen clogged with mineral deposits and tiny ... How to Repair a Leaking Washing Machine ... The onlytricky part is removing the screens without wrecking them (Photo 1).
Speed Queen & Amana Washing Machine Repair Manual ...
www.appliancerepair.net/washing-machine-repair-8.html
Online washing machine repair manual CHAPTER 8 - written ESPECIALLY for do-it-yourself ... Belt driven pumps are replaced by simply removing the pump mounts. Tension ... Pump or belt changing on a direct drive machine is a little trickier.
How to Remove Mold and Mildew from Front-Load Washing ...
www.todayshomeowner.com/how-to-remove-mold-and-mildew-from-fr...
Jan 10, 2016 | Washing Machines
Washer makes a buzzing noise when it tries to spin
Hello. Loud noises coming from a Washing Machines are most often caused by looseobjects inside the unit or by a broken dryer belt. The Washing Machines beltallows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually Washing Machines cracking and thensnapping. This will cause a loud noise within the unit. Repair and fix thedryer belt of a Washing Machines to get rid of loud noises. Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt 1 Stop the Washing Machines and look inside the dryer's drum for any looseobjects such as coins, pens or anything else that may have been in a pocket ofclothing. Remove the object and restart the dyer to determine if the noise hasstopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power tothe unit. 3 Remove the lint trap from the lint compartment on the top of the dryer. 4 Remove the screws that hold the top panel in place. Pull the panel off toaccess the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check theWashing Machines belt. A belt that is worn, cracked, split or broken will causeloud noises. 6 Slide the old belt off of the drum and pull it out to remove it. Take noteon how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines andslip the new belt over the drum. Locate the position of the old belt and slipthe new belt following the old belt's position ensuring the grooved side of thebelt faces down. Push the idler pulley towards the motor to allow you to slipand loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drumcounterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use . Thanks.
Sep 13, 2011 | GE Energy Star WCVH6260F Front Load Washer
Hi i have a speedqueen awm373w-3062 have noise on
Hello.
Loud noises coming from a Washing Machines are most often caused by loose objects inside the unit or by a broken dryer belt. The Washing Machines belt allows the dryer's motor to run smoothly. Continuous wear and dry conditions may cause the belt to dry out, eventually Washing Machines cracking and then snapping. This will cause a loud noise within the unit. Repair and fix the dryer belt of a Washing Machines to get rid of loud noises.
1 Stop the Washing Machines and look inside the dryer's drum for any loose objects such as coins, pens or anything else that may have been in a pocket of clothing. Remove the object and restart the dyer to determine if the noise has stopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power to the unit.
4 Remove the screws that hold the top panel in place. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check the Washing Machines belt. A belt that is worn, cracked, split or broken will cause loud noises.
6 Slide the old belt off of the drum and pull it out to remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines and slip the new belt over the drum. Locate the position of the old belt and slip the new belt following the old belt's position ensuring the grooved side of the belt faces down. Push the idler pulley towards the motor to allow you to slip and loop the belt around the motor pulley.
9 Open the Washing Machines door and use your hand to rotate the drum counterclockwise a few turns to ensure the belt is secured.
Aug 02, 2011 | Washing Machines
Timing belt replacemnt for 1991 Nissan pulsar
1. Disconnect battery.2. make sure the engine is at top dead center(TDC).3. take belts off.4. Remove pulleys,except for the camshaft pulley..5. Remove timing belt cover.At this point you should see the timing belt and also the water pump,if it's not external.I suggest while you have access to the water pump that you replace it.6. loosen timing belt tensioner and and finally remove belt.On the camshaft pulley,there should be a notch,making sure the notch is at the top of the pulley. 7. Tighten the timing belt,but not too tight.7. Installation is reverse of removal.
Oct 02, 2010 | 1990 Nissan Pulsar
What is the current smart thinking advice about Audi A4 2L manual timing belt water pump etc replacemnt mileage.
The current smart thinking advice about Audi A4 2L manual timing belt water pump etc replacemnt mileage is 115 000 miles (180 000 km).
Sep 16, 2010 | 2006 Audi A4
My HP Deskjet ink drive belt has broken, where do I find a replacemnt?
It's quite difficult to get a belt replacement. When I need one, I go to the flea market or Good will stores to buy a broken printer with a belt in good condition. I usually pay 5 to 10 USD for a printer that I'm going to use for spare parts. Sometimes I also get a working cartridge worth of $15 USD with the printer.
Dec 22, 2009 | HP DeskJet 895cxi InkJet Printer
I need to replace the belt on my Miele washing machine. Can you tell me how to do it?
Open the washing machine's back access panel.Depending on the make and model of your washing machine,you may need a screwdriver to unscrew the screws that hold the panel up.Locate the washing machine's drive belt.It will be in clear view,detach the old drive belt.Use the screwdriver to unscrew the pump coupling.Then gently slide the old belt off of the drive belt notch.If the belt is broken,be careful not to leave any pieces in the washing machine's interior. Slide the new washing machine drive belt over the drive belt pulley in the machine.Carefully stretch the belt up and over the second pulley before releasing.Use the screwdriver to re-attach the pump coupling.Test the drive belt's tension.If it is looser,tighten the pulleys to increase the belt's tension.Replace the access panel and resume using your washing machine.
Aug 27, 2009 | Miele Washing Machines
Kemore washer series 80
Replace the timer.
Reply with a FULL model Number or go HERE and enter it in, and select timer in the parts menu.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 17, 2009 | Kenmore 24032\24036 Top Load Washer
Where to buy a replacement pump?
GO to google and type in "Kenmore appliance parts"
You will get 10 pages of hits on where to buy  appliance parts or go to you local appliance parts store where you live.
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Agitator flutes are breaking off
the agitator can be removed easily, remove the center fabric softener cup and down the center of the agitiator shaft is a wing nout you can remove by hand, simply remove agitator and replace with a new one. call F&P for the replacemnt part
Nov 02, 2008 | Fisher and Paykel GWL11 Top Load Washer
Zanussi FJS1225W Front Load Washer Logo
32 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
