Question about Peavey Electronics Peavey Pv6 6-channel Compact Mixer With Power Supply
Why all red leds become on when i power my pv6 mixer?
3 Suggested Answers
  • 5603 Answers
SOURCE: my pv6 mixers red clip lights remain on
FIRST check that your power adapter is 16 VAC at 1 AMP and that it is the original unit.
The clip lights monitor levels at several points. If you cranked the EQ's for maximum, say bass, that MAY cause them to illuminate.
As a test, set all EQ's at mid point. Remove ALL input cables. Are the lights still on?
It is possible that you can have a ground loop that is putting signals in that causes clipping. Another source is if you have a microphone that may be FEEDBACKING at supersonic frequency that you can't hear... that is why we disconnect all the inputs as a test.
Finding schematics so one can repair these devices can be a problem. If ALL the clip lights ar on, then it is probably the reference level source for the clip level threshold... however finding a schematic would be necessary and while part cost would be probably under a dollar, the labor and time to find the schematic would be unknown.
Posted on Dec 28, 2009
  • 5603 Answers
SOURCE: all the channels shows the
It is likely there is a failure of one of the power supply voltages. The solution requires troubleshooting that is NOT DIY unless you are electronically skilled.
Posted on Oct 26, 2010
What is the power supply number for peavey pv 6
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Mar 26, 2014 | Peavey PV6 Mixer
How ti install in chain to amp input
the instrument should be plugged into the LINE jack, and the amp should get it's signal from either the MAIN L or R jacks
Feb 17, 2014 | Peavey PV6 Mixer
Problems
This may be an issue with your power supply regulation, check opamp's ic's for +15V at pin-8 and -15V at pin-4, this may help to troubleshoot the issue.
Jul 03, 2013 | Peavey PV6 Mixer
Clip is on as soon as I turn power on.
Sometimes this may be a result of a subsonic or supersonic signal, if it still does it with nothing at all plugged in and the FX turned right down there is a fault with your mixer.
Apr 16, 2013 | Peavey PV6 Mixer
How to get efx to work
You are aware that there are no built in effects, correct? Are you connecting an off board effects unit and having problems with that? You should be connecting the effects send on this mixer to the input of the effects unit - then the output of the effects unit to the effects return on the mixer. With the effects send control on the appropriate channel turned up, you should see signal hitting the effects unit. You'll need to adjust the effects return on the mixer to hear the effects signal included in your mixer output.
Aug 05, 2012 | Peavey PV6 Mixer
Manual for Peavey PV6 6 channel mixer
Aug 05, 2012 | Peavey Electronics Peavey Pv6 6-channel...
All the channels shows the Clip red light on the Peavey PV6 6 channel mixer and I´m unable to use the device ...Whats is the solution??
Oct 26, 2010 | Peavey 32fx USB 32 Channel Mixer
I have 2 peavey 2600 amps with 1 pv6 mixer wanting to run subs off 1 amp and sp2s off other amp but only have 1 main output on the pv6 mixer whats my solution
you can run one amp from the main out puts and the second amp from the CTRL Room out puts. The CTRL ROOM are outputs that are linked to the same bus as the master fader. This will work fine...
Best of luck
Sep 02, 2010 | Peavey Pv 2600 Power Amplifier
My pv6 mixers red clip lights remain on
Aug 18, 2009 | Peavey 32fx USB 32 Channel Mixer
PV6 clip lights stay on
You've lost one of the power supply rails. It needs to be repaired or replaced.
Jan 15, 2009 | Peavey 32fx USB 32 Channel Mixer
Peavey Electronics Peavey Pv6 6-channel Compact Mixer With Power Supply Logo
20 people viewed this question
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
