Question about Electronics - Others
Pny instructions I'm trying to find instructions for how I use the multi-slot usb &flash card reader p-usbdrdr21k-rf from the start to finish.please
  • 9,742 Answers
Http://www3.pny.com/support/support_landing_cat.aspx?SectionID=1057 See if you can get what you want here.
Posted on Jan 20, 2014
pshinde23
  • 136 Answers
SOURCE: My computer does not recognize my SD 2GB SD Flash
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Posted on Jun 25, 2009
SOURCE: pny usb 2.0 flash drive memory stick
windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
Posted on May 28, 2008
  • 10406 Answers
SOURCE: My 4GB PNY Optima sd card will not read
Try the 4GB card in some other reader, or your camera, to confirm that it does work.
It's possible that your card-reader will not support anything over 2GB.
Posted on Dec 10, 2009
SOURCE: PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Posted on Jan 07, 2010
SOURCE: i get a card reader error on my printer when i
Has the card worked before.If it is the first time you have tried,is the SD card an SDHC,as some printers will not read these.Try a standard SD card and see if your printer reads that.Hope this helps.
Posted on Apr 12, 2010
I have a PNY usb 2.0 combo. The usb ports work fine and read external drives etc. The SD readers quit working. The SD cards read fine on the internal mounted reader. My PC recognizes the drives, and t
I bought a deer cam (trail camera) at Walmart and a PNY card with PNY Multi-Slot USB & Flash Card Reader P-UBSDRDR21K-RF. I can't make them all work for me. PNY card reader has no instructions on the package neither on their website and their support is a joke. When I plug in this multi-slot card reader into my PC (I tried two different PCs) something isn't right. I get no results, just empty folders. The card is new and has data on it. Both products come from PNY, both were purchased at Walmart and both are going back to Walmart for a full refund and I will never buy a PNY product ever again.
Feb 14, 2013 | PNY Memory Card Reader and USB Hub Combo
How do you see the pictures with on your computer with this memory card?
Upload to your computer with your camera or have a card reader installed on your computer or get a USB card reader you can get these at any computer store or retail store. Here is a link to one Click Here
Jan 08, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
I am having Intel pantium 4 computer that configration is windows 2000, when i am trying to read 8 GB memory card that drive is comming but at a time of try to opend masage is is comming as PLEASE INSERT...
It sounds as if you have an SD card reader, not an SDHC card reader. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. SD devices are limited to cards 2GB and smaller. SDHC cards begin at 4GB and go up to 32GB.
Nov 26, 2010 | PNY 4GB Secure Digital High Capacity...
My computer is not recognizing my PNY SD 1GB memory card. I can still take pictures and my camera saves them to the memory card, but when I try to transfer the pictures to my computer, it does not...
In this instance, you might want to consider either borrowing, or, purchasing and card sd reader. Some computers just don't read these cards from their built-in slots, so, using an sd card reader often fixes the problem.
Hope this helps. :)
Oct 06, 2010 | PNY 1GB microSD Memory Card
Can't upload videos HELP
check the card with anothe computer if it works then check ur card reader if not then its the problem of your card change the card reader then try.
Oct 17, 2009 | PNY 4GB Secure Digital High Capacity...
PNY Optima SD HC 8GB isnt working on laptop
Youll have to get updates for your laptop card reader or get a new one which may have to be installed. Another method you may want to try would be to put the card back into the device you used it in and then hook the device up to the computer, most likely through the USB slot....good luck
Jun 05, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
My PNY Micro Sd card is not working at all
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Mar 29, 2009 | PNY 4GB microSD High Capacity Mobile Media...
How do I instert a micro SD adaptr into a HP windows Vista laptop
micro sd are too small usually, you need a Micro to SD sleeve, you simply slide the micro into an SD size sleeve and then just put it in your SD slot if no micro slot etc, or buy a usb multi card reader , hey presto
Mar 14, 2009 | PNY 1GB microSD Memory Card
I bought two 4 GB PNY Optima SD HC 60 HD cards for my Canon PowerShot SD 800 IS Digital Elph for a very special event. It captured all of the photos as my other cards have, but when I went to download the...
pny does not supply card readers w/memory cards-sandisk on certain cards includes reader because file format is different on sdhc cards -try downloading direct from camera w/usb or get a card reader that absolutley supports sdhc type cards-not all readers do!
Jun 25, 2008 | Cameras
Drivers for multi slot card reader
try to install windows xp and see,,,xp requires no drivers
Jan 01, 2008 | Electronics - Others
Electronics - Others Logo
319 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
