Question about GE WSXH208A Front Load Washer
Water leaking out of the bottom
My front loader was leaking water out of the bottom onto the floor and now it is leaving about 2 inches in the bottom with the clothes after the load is finished
    President:
  • 1,902 Answers
Sounds like the main bearing has gone bad and that is causing you to loose water on the floor. There is also a rear seal back there that will need to be replaced
Posted on May 22, 2009
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
My 4 yr old Whirlpool Duet front load washer is leaking water onto the floor from the bottom of the machine. It seems to be coming from underneath or back, it is not coming through the door. It's not...
The most frequent place for a front-loader to leak is on the door connector boot. The boot connects the drum to the door. You can often remove it and replace it upside down and that will give you a few more months' use.
Jan 23, 2015 | Whirlpool Washing Machines
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
The washer leaves water remaining in drum after the entire wash cycle, it becomes stale and makes my clothes that I was smell. My father's front loader, GE, does not leave any water in the drum
Hello
Check the drain tube,it needs to be 30 inches above the floor.
Also if the drain tube from the washer is too far into the drain the washer will not drain completly.The drain tube should be 1 inch into the wall drain.
Also check for kinks or obstructions in the washer drain tube.
May 13, 2010 | Samsung WF203ANW Front Load Washer
Water leaking from bottom of machine onto floor during fill and wash cycle
there are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
Sep 07, 2009 | Kenmore Elite HE4 Electric Dryer
Smeg fride freezer leaking
HI Mark,
The evaporator drain is blocked causing the defrost water to pool, freeze and then leak onto your floor.
Clear out the freezer, then use a hammer to break up the ice on the floor. Now remove the rear panel. You'll see more ice build up. Don't use the hammer on it! (Too close to the coils for comfort) Use a hair dryer to warm up/melt the ice below the coils.
You'll see the drain hole now. Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
SG
Mar 27, 2009 | Smeg FA561X Side by Side Refrigerator
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
http://tclaundryrepair.com/
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Leaking door at the bottom
the vacuum which is to be created between the door and the tub must be not working......try cleaning the door ..some unwanted things may be blocking this to happen
Jan 02, 2008 | Whirlpool LHW0050PQ Front Load Washer
GE WSXH208A Front Load Washer Logo
364 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
