Question about Exercise & Fitness
Long jump pit size - Exercise & Fitness
How long is the brake cable for a 1991 Honda Z50 pit bike?
Hello Cecil,
  1. Front Brake Cable - Extended for aftermarket tall bar and fork kits. Overall Length 40.25inches or 1022.35mm. Jacket measures 35.25inches or 895.35mm.
    Try that for sizing on your Z50 Pit Bike.
    Hope that helps you out.
Nov 19, 2014 | Honda Motorcycles
Are ball pits safe?
It's not easy for anyone to claim that Ball Pits are definitely safe. There are can be potential games in many kids toys and games.
Ball Pits are great fun for kids but you should be aware of the following risks:
1. Ball Pits can be filled deeply with balls and so you can't see the bottom. if there are any sharp objects etc at the bottom, there is a risk you will miss them.
2. Its hard to clean Ball Pits and if you are in a public play area, it's possible that the Ball Pit might be a haven for bacteria.
3. There is a risk of injury as kids tend to jump really high into ball pits and arent' always sure where they will land.
Jan 14, 2013 | Toys
What is a Ball Pit?
A ball pit is a padded pit (usually square or rectangular) that is filled with hollow plastic balls. The aim is for kids to have fun jumping inside the pit without any worry of getting hurt.
A lot of gymboree type places have large ball pits.
Jan 14, 2013 | Toys
How long should your jump rope be for exercising?
If you are 6 feet or shorter, than the rope should be 9 feet long. This is the standard jump rope size found in stores. If you are over 6 feet then you'll need a 10 foot rope. Generally, when you hold the rope and stand on the middle with your feet, each end should reach your arm pit.
Jan 03, 2013 | Exercise & Fitness
How do i increase the water pressure in my gas boiler
Check the sand filter is not blocked
Check the pump size is ok for the filter size
Pit your multiport to recirculation to give the boiler full pump presure.
You may have a pressure switch fault
Oct 09, 2012 | Lite On Laars Lite 2 Heaters: 250,000BTU...
In 3-2 the tombs when my partner in i have 2 run then jump then run the last jump what do we have 2 do so we dont keep fal
First after the cut sceen rapidly tap the "A" button, wait for the on screen prompt "X" or "B" and hold that button down untill you have cleared the pit and go back to rapidly tapping the "A" button repat this for the second pit and also the third however as soon as you land having cleared the third pit you will see another on screen propmt to press the left and right triggers at the same time and hold them down until sheva has pulled chris to safty.once you get used to doing this it is probably the best level for "harvesting" with 25 gems an idol and the granade launcher.
Jan 17, 2012 | Capcom Resident Evil 5 for Xbox 360
Gas seems to be jumping around the gas fire pit
A gas appliance is not something that one should be self repairing without the proper knowledge and training.
If you think it has a problem with gas "jumping around the gas fire pit" it could indicate a leak somewhere that could build up and cause an explosion and fire with serious or fatal consequences.
I would turn off the gas supply and contact a qualified service person to have it checked out properly.
Oct 24, 2009 | Forest Natural Gas Fire Pit Black Marble...
Exercise & Fitness Logo
46 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
