Question about Panasonic TU-PT700U DTV Receiver
My rcvr will turn on but the tv screen is blank.
We get sound but no video.
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Can't get the tv sound to come through the surround receiver
This question does beg for more details. For instance, some HDTVs have an optical out which can be hooked into the Denon. This works great when the unit doesn't have HDMI I/O. I have one such Denon unit [1312] which I bought for that exact purpose. It's all I could afford, and it works. You do have to have the rcvr set on TV or whatever the optical in goes to.
Or, some people have a newer Denon and setup their RCVR to switch and only one TV input from the RCVR. then it's the cable box connection you need to check/switch to. it's not simple, but it's not that hard either. I you need more help you can PM me.
Feb 10, 2014 | Denon AVR-1601 Receiver
Yamaha rx-v663. Want to watch cable tv while listening to cd (blue ray).
Don't think there is a way to make that happen with your setup
Dec 31, 2012 | Yamaha RX-V663 Receiver
I just bought a Yamaha 5.1 system with rcvr RX-V365 i have HDMI to tv then HDMI to RCVR then another HDMI to DTV. Problem cant seem to get picture AND sound together through RCVR. depending on what setting...
RX-V365 doesn't support sound over HDMI. It can switch the video+audio from HDMI in to HDMI out, but can't play the sound through the speakers. You need to connect the audio separately via optical or coax digital cable.
Mar 19, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I'm trying to determine whether my new rx-v665 (store display model)is defective or is incapable of doing what I expect it to do. Examples are: when I connect a Samsung Blu-ray ''hdmi'' out to ''hdmi1'', I...
If you want picture to pass through the receiver to TV via HDMI then HDMI is the only cable that you can use for both connections. Video signals designed for an HDMI output will not pass through component video connections, they are not compatible. Your best result will be to either continue using your component video connection but connected directly to the television or use the HDMI connection on the TV if available.
Feb 08, 2010 | Audio Players & Recorders
I have 2 receivers and 2 remotes, one per receiver so we can watch separate programs on different tvs, but I dont know how to program my 2nd receiver to the remote. We used to have each receiver set to a...
Just to clarify is your screen snowy or blank? I ask because you did say it was set to a channel. If you just need to program the remote to the reciver all you have to do is whiile your rcvr is on pull the sc out on the left hand side. That will take you to a screen that says system info and at the very bottom of that screen you will see remote address. Note the number in the white box. Now all you have to do is press record on the remote( should be right above the number 3 key). Then your remote should be addressed, and the number in the white box should change. If not please let me know there might be some more trbleshooting that has to be done. Then put the smart card back in and your rcvr will reset and all is well.
If you arent getting a picture try ch 3 then ch 4. then cycle through your tvs inputs. Like video one video 2 and so on. These steps should get you a picutre back.
If not again please let me know there is more trblshooting for no video.
Sep 18, 2009 | DISH Network 311 DTV Receiver
Blank screen when ps3 is turned on.
If you can still hear sound make sure your video output is compatiable with the setting on your tv example dont try to put 1080i if your tv can only run 720i
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
Sony Grand Wega KDF-E50A10 showing msg about unauthorized content HDMI
Did you select the output of Cable box to HDMI out? I think it is in the menu setup on most cable boxes. It maybe active but if it isnt, try this.... Hold Menu button down and see if setup menu comes up and then toggle with arrow buttons on front of settop box and try and select HDMI if it is in there. Also make sure settings are on in the T.V. menu as well. Let me know and we will continue. Thank you ...GURU JAY
Jan 30, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Panasonic TU-PT700U DTV Receiver Logo
131 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
