Question about Bandit Extreme Sports Buggy with Battery & Charger TRA2405
My bandit donna kebab keeps saying reel unit missing unit o
My bandit is hitec awp with secondary feature game
Pull cord will not retract
You did not say which model of vacuum you have. Cord reels are a great feature on a vacuum, when they are working properly. If your cord goes bad or the cord reel isn't working correctly it may need to be replaced.
Apr 03, 2016 | Vacuums
Holman retractable hose reel won't retract garden
it is possible the rewinding spring broke .
Jan 07, 2014 | Karcher Hose Reel
Can't sign in to Reel Deal Live due to driver "missing"
Its telling you that Ogremain dll is missing from your computer.
Do a search for OgreMain DLL download and install it
Aug 03, 2017 | Computers & Internet
Where is ignition coil located in 2004 jetta
  • Remove the ground battery cable from the negative terminal battery post. This prevents sparks, which can cause an fire, when metal tools make contact with the engine. Also, set your emergency brak engen.
  • Determine which type engine you have. The 1.8L awd 1.8L (Aww and Awp) and the 2.8L (Bdf) require slight variation in the replacement process.
  • Use a Phillips head screwdriver to remove the screws that hold the engine cover in place. Then lift off the cover.
  • Expose the Jetta ignition coil. On a 1.8L (AWD) engine, you need to remove the recirculating valve and the secondary air inlet valve and their mounting systems. For the 1.8L (Aww and Awp) engine, you take off the hex nut and vacuum reservoir. The 2.8L (Bdf) engine doesn't require the removal of additional components.
  • Unscrew the retainers securing the Jetta ignition coil.
  • Separate the old ignition coil from the cylinder head. On the 2.8L (Bdf) engine, use Puller T10095 to release the Jetta ignition coil. You may need to twist the ignition coil to break the seal between the parts
  • Nov 28, 2010 | 2004 Volkswagen Jetta
    Hi, My electrolux EWT 959 washing machine keeps saying please close the lid when the lid is closed. The machine filled up full of water before saying this & now wont finish the wash. Are you able to...
    Hi Donna,
    I just wondering have you solved the problems? as I have a similar problems in the same washing machine model. Please advse if you've solved the problems and how
    Thanks
    Nov 14, 2010 | Washing Machines
    SMT transistors marked UXR and UYR I need further information so that I can source for repair
    I had the same probem with my Hitec HS225 servo.brand new one that I opened and played with a little too much = (
    I found out that hitecs cheaper servos has identical electronics inside and I managed to transfere one.
    //Olle
    Oct 23, 2009 | HI-TEC SPORTS Hitec 11.2g Hs 65HB Mighty...
    SHIMANO FISHING REEL
    The drag is set by turning the knob which secures the spool to the reel.
    To cast, hold the line against the rod with index finger on right hand. Then flip the bail open which frees the line to come off the spool. The bail, when it gets to a certain point will lock open. When casting, release your finger on the line when the rod gets to 11 o'clock.
    Flip the bail back by turning the reel handle -- the bail will pop back over the reel -- then you're ready to reel it in.
    The bail is the wire-like device on the top of the reel.
    There is probably a button/switch for turning anti-reverse on & off -- when on, this keeps the reel from turning backwards when force is applied to the line.
    I think those are the highlights.
    Charlie
    Sep 10, 2009 | Shimano REELS TYR20 Tyrnos Lever Drag...
    Bandit Extreme Sports Buggy with Battery & Charger TRA2405 Logo
    14 people viewed this question
    Top Traxxas Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Traxxas Vehicle Part and Accessory Expert? Answer questions, earn points and help others
