Question about Sony KP-51HW40 51" Rear Projection Television
Double pictures Suddenly I see a shadow of faces of different colors. All writing also have shadow.
  • Sony Master
  • 3,459 Answers
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on May 22, 2009
Picture has ghost shadows in the faces of people mainly news anchors. Light colors like whites and oranges also have shadows. What could be causing this?
If it does not really display this when a DVD etc is played via a rear audio/video input it is not the set.
Modern cable or sat signals often are compressed and sets cannot on close up views keep up with the signal--when signal is compressed it causes this kind of issue--no way around it.
Jun 16, 2012 | HP Pavilion MD5020N 50" DLP HDTV
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Different color shadows. Double or triple vision
replaced convergence IC.what is the model#?
Oct 04, 2009 | Televison & Video
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Yellowish tint on faces, shadows, gold backgrounds
Check the white balance setting of the camera. As you have a yellow cast, it could be because you are using it in Fluorescent (or Tubelight) setting. Changing this to Auto should solve this problem.
Jan 22, 2009 | Fuji FinePix S1000FD Digital Camera
Printing color shadow
did you used a combat able cartridge ? if yes the ink is the problem if no the problem is firmware
Sep 04, 2008 | HP Color LaserJet 2600n Printer
TV PROBLEMS
If the images are different colors (red,green,blue) then the convergence has diverged. Some TV allow re-convergence through the menu screen, older sets my need to be physically adjusted (aimed) to clear this up. a strong knock to the TV may have cause this.
Apr 21, 2008 | JVC AV-56WP74 56" Rear Projection...
HITACHI ultrascan hd tv....
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 24, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Duel pictures
are the shadows a different color... if it is this is a convergence problem
Jan 02, 2008 | Philips 60PP9202 60" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
196 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
