Question about Kicker CVR12 Car Subwoofer
Multible amp wiring
Ok i have a kicker cvr and a kicker impulse a tma amp and a pyramid amp is it safe to connect the pyramids power wire into the terminal of the tma where my power cables connected or do i have to distribute block it my power cable runs into tma terminal can i run the power wire for pyramid to terminal on tma
    Novelist:
  • 149 Answers
Its always a better idea to use a distribution block when splitting your power source to multiple amplifiers-but you asked if it would work not what a good idea is -so to answer you yes it will work -im not recommending it but sometimes ya gotta do what ya gotta do
Posted on May 22, 2009
Is my Pyramid 300 watt mosfet pb 772 compatible with a 10" kicker comp sub?
If the output impedance of your Pyramid amp is approximately the same as the input impedance of your Kicker, it should work.
May 12, 2014 | Kicker Car Audio & Video
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
How do i wire a single 12" kicker cvr dual 2 ohm
Simple power fom amo to power on sub. Ground on amp to ground on sub
Feb 28, 2013 | Car Audio & Video
What's the best way to wire a 12 inch kicker CVR
Ok, first you need to have at least ten gauge wire cause the amp needs agility of juice. Next you want to find a good ground to frame of the car (if its wrong you'll hear road noise through speaker.) Next look on the fire wall and find the terminal that has other wire coming to it (one from positive to the amplifier on battery the rest out top other you want to put an inline fuse to amp.and have ground write other side of the cart than the power. run write to amp then to your speaker I believe I made it is simple for you as possible good luck
Dec 07, 2011 | Kicker Car Audio & Video
How do i install a pyramid pb880 4 channel mosfet amplifier?
run rca cables and a remote wire from your radio to the amp,run a power wire from your battery and attatch a ground to the car ,then hook up the wires and cables to there respective places.
Jan 15, 2011 | Pyramid Car Audio & Video
I have two Kicker dvc cvr's 12's and I want to hook them up to a Kenwood KAC-520 1000 watt amp. Whats the best wiring to wire these?
The best thing to do would be to get an amp installation kit, at an auto stereo store or Wal-Mart automotive department. It will have the wiring and connects that you'll need to wire everything up.
May 19, 2010 | Car Audio & Video
I have a 300 watt amp, but i just bought 12 gauge wire why wont it allow sound to come from my 12'' sub
There is no reason even if the wire was to small it would still allow ssound.make sure you have good connections.
Nov 08, 2009 | Pyramid 906 300 Watts (peak) 10 Band...
CAN PYRAMID PB-772 BE BRIDGED
i cant find a whole lot of information on that amp or any other older pyramid as they arent exactly the most popular amp but just applying what i know about amplifiers in my opinion i think the amp is more than likely only stable @ 4ohm when it is bridged and @ 2ohm in stereo (using both channels) so yes you should be more than likely able to bridge it because the impulse only came in 4 and 8 ohm voice coils and i dont think they made a dvc impulse so check the sub paperwork . if you dont have the paperwork look at the sub and check for it or get the model number and ill be able to tell you what the ohm rating is on it and remember if u decide to bridge it be carefull not to turn the gain up like it is the volume controll. it should typically be set under half way but you maybe ok going up to 3/4 but i am not sure how it will sound @ that level so if its not loud enough after that you should consider getting a slightly larger amp ( a good rule of thumb that i have found is that the subs rms specification should only be 2/3 of the totall rated rms output at the ohm load that the speakers or speaker are as this should allow u all the spl you want without really heating up your amp and if u ever buy new subwoofers you have more power left in the amps output capabilities because when u buy new subs it is usually to upgade in quality which usually requires more wattage and youll have it
sorry my answer is so long . if u have any problems pls feel free ask me
and again you should be very capable of bridging it just find out the ohm load for the impulses voice coil HOPEFULLY it is an 8 ohn because when bridging an amp it halves the ohm rating on the sub
sorry such a long answer but i just wanted to cover as much as i could in case you have any problems if u have wiring questions or want to see a wiring chart go to www.the12volt.com for all kinds of excellent information charts wiring wizards and here is the link to the subwoofer wiring wizard
http://www.the12volt.com/caraudio/woofer_configurations.asp
thanks for letting me try to help out and god bless
May 22, 2009 | Kicker CVR12 Car Subwoofer
Pyramid eq 906vl no remote lead
that unit use just two power wire you have to connect it to an accessory power source that turn of by your car radio
Oct 08, 2008 | AudioBahn AEQ6 5-Band Car Equalizer
Kicker CVR12 Car Subwoofer Logo
908 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
