Question about Panasonic TCP42G25 42 in. TV
10 blink code
It was working a few hours previous and I just tried the TV on and the power light started blinking 2 times at a time. I then unplugged it and plugged it back in and it now blinks 10 times. Help!
    Top Expert:
  • Panasonic Master
  • 74,459 Answers
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Posted on Jan 03, 2014
djchillsnyc
  • 151 Answers
SOURCE: red light blinks 9 times on Panasonic TH-42PZ77U
hello, panasonic plasmas have a safety shut down circut to protect the main panel when a short is present or internal circut panel is non functional some info i found in the service manual for 10th generation plasma
if your tv is still under warantee take advantage of the pany free service other wise it is a matter of exchanging the defective board then you will need electronic skills for this repair if you plan to do it yourself. it would be wise to have a skilled tech check it out and give you a estimate there are some techs that will come out and check it for free and give you a repair price.
here are some repair manual tips for blinking panasonic .. i didnt find 9 blinks on this manual i may be using a different manual but these are panasonic plasma blinking fault tips for 10th gen
becuase all models have different blinking codes you may need the model specific service manual
for 10th gen model some models 2008,2007,
8 Blinks SOS:
Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
9 blinks panel config sos
10 Blinks SOS:
The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS:
The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
hope this helps..
Posted on Dec 09, 2008
djchillsnyc
  • 151 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
  • 20 Answers
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Posted on Jan 04, 2009
SOURCE: TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Posted on Jan 06, 2009
stonephoenix
  • 563 Answers
SOURCE: when we turn the tv on the light just blinks 10 x, but wont t. on
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 18, 2009
Panasonic viera th-50pz800u won't turn on. Red power light blinks 10 times.
thats a sos error for numerous supply voltages missing. Send a email to me for assistance as I cant post the info here slinteriors@yahoo.com
Apr 01, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
Power surge from storm. Power light turns on for 2-3 seconds and goes off. Previously had a power supply replaced 3 yrs ago. tv is approx 12-15 yrs old.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
before you rate this information or if you have questions let me know what you find.
SD TECH
Jul 25, 2011 | Mitsubishi WS-55511 55" Rear Projection...
10 red blinking lights on my Panasonic Plasma TV, will pause for few seconds, then blinks again. TV will not power on.
This is a power supply issue - found a company that has used power supplies, they sell them for $60.00. We recommend a professional install the board because the voltage needs to be adjusted after the install or you could damage something else. The high voltage in the set can KILL you soe be very careful. The web address for the PS board is plasmafix.com.
Jun 24, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
Standby light blinks twice after turning itself
this a code that mean overvoltage in power supply (+B)
Mar 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
10 BLINKS AND GO DEAD
Standby tech diagnostic codes.
Panasonic seems to be having some issues with this on newer sets.
They are a good brand but this is not very good and pretty common.
Do a search for Panasonic TV codes
Usually its related to the current and circuits to fire up the set.
After unplugging for a time, a few hours maybe over night. A few minutes may not be long enough. Try plugging directly into a wall outlet by itself, do not use a surge/protector or power strip.
Some have success by even moving connections around such as DVD player or cable box to a different port.
This is worth trying if the TV is out of warranty because truly it could work but check out the codes for 10 blinks first. The number of blinks tells what the problem is. I do not codes for Panasonic.
I have a similar problem that is extremely common on my Sony and it wouldn't start, 6 blinks. Removed it from surge protector and plugged other equipment in a different outlet.
I have plugged directly into the wall and it will fire up now, When I am done I unplug at wall to reset standby. The set is not worth the $500 bills to repair so until is, yours may be.
Aug 22, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Turn on the power and the green LED blinks on the front for a second, but tv does not power on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
Jul 30, 2009 | Mitsubishi WS-55411 55" Rear Projection...
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
Nov 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic TCP42G25 42 in. TV Logo
100 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
