Question about GE WSXH208A Front Load Washer
Washer shakes vigorously
Washer shakes only with clothes in it without clothes it runs great.
  • flinsky Nov 28, 2007
    loud noises while in rince cycle. Nee info on removing drumb
    President:
  • 1,294 Answers
The front 2 legs should be screwed in completely, and locked with the check nut. This means the machine is lowest in the front. If you find any shake (try with both your hands) adjust accordingly. Normally the machine adjusts itself if the weight is un-balanced; but it cannot do anything if the legs are uneven.
For Flinsky:
There could be some spring or shock-absorber come loose inside the machine. Plug off the wall, remove panel behind & check. If you could remove the top to check fine.
Posted on Dec 04, 2007
Whirlpool - hot inlet hose shaking badly when filling water
check to see if the screen is clogged were water hooks up to back of michine
May 11, 2012 | Whirlpool Washing Machines
Washer shakes vigorously, when it goes into spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jul 17, 2011 | Maytag Washing Machines
I have a Frigidaire gallery Heavy duty extra large capacity Front loading 2 way tumble action washing machine. It rocks,shakes when it is in the spin cycle. I got it levelled, still it continues to...
If your transport bolts are removed and if the springs or shocks are in good order, make sure the machine is not standing on a tiled floor. No matter what, it will bounce all over the floor then. Place machine on a concrete floor and retry.
Aug 05, 2010 | Washing Machines
Shaking and moving washer
my washer shakes when its washing clothes
May 23, 2010 | GE WPXH214A Front Load Washer
THE MACHINE SHAKES WITHOUT CONTROL
During the spin cycle if your cloths are too heavy on one side you will get this problem, reposition the cloths and it should cure the problem, at least thats what I do when my machine gets to shaking.
Aug 28, 2009 | Maytag MAH8700A Front Load Washer
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
Washer wont rinse
you have a pump problem, need to lean washer back ageist wall go under washer. front left take off both hoses stick finger in pump remove all items from pump &hoses should work now
Aug 04, 2008 | Maytag MAH2400A Front Load Washer
Lens on front headlights of 2001 Civic "fogged" to the point that light is greatly diminished!
maybe there is a small crack or air can seep into the headlights.
try to acquire a sealant (clear) and seal the sides of the headlights and check the rubbers on the light fixtures.
hope it helps.
Aug 02, 2008 | 1996 Honda Civic
Kenmore 80 series washer wont rinse/spin
I fixed the same problem by using this site: http://forum.doityourself.com/archive/index.php/t-156215.html
Mar 17, 2008 | Washing Machines
Kenmore model417.41142000
I just went through kinda the same problem and when I took it completely apart I found the spindle hub was broken on 2 of the 3 supporting arms. they where just eaten up bad/corroded. I had to buy the tub/spin assembly which is the techincal name if you happen to need this part.once you pull tub house out of washer you need to split the tub and then you can see if this is the same problem I had
Oct 19, 2007 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
106 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
