Question about Fargo Persona C30 Thermal Card Printer
Error=126 failed to add printer driver
Windows cannot connect to printer. Operation failed with error 0x0000007e.
This problem happens when you are trying to share printer between 32 bit (x86) and 64 bit (x64) Windows. The 32 bit driver not compatible for 64 bit operating system. At this situation you may get error message like this "Windows cannot connect to the printer Operation failed with error 0x0000007e".
But there is an alternate way to add printer from 32 bit Windows to 64 bit Windows.
Start >> Devices and Printers >>
Then Add Printer with the help of IP address of 32 bit Windows computer.
Detailed steps with screen shots are given in the following link.
[Solved] Operation failed with error 0x0000007e
Solved Operation failed with error 0x0000007e Share printer between 32...
Apr 11, 2012 | Xerox Office Equipment & Supplies
I keep getting the message failed to create print object Lexmark 6500 series. The specified module could not be found. (126)
It coudl be a printer driver issue. Please follow the steps below to fix the problem.
First, uninstall your existing print driver. On your computer, go to Start menu > Programs > Lexmark 6500 Series > Tools > Uninstall. After the uninstall process, reboot pc when prompted.
Second, visit the Lexmark website to download and re-install the Lexmark X6500 printer driver. Select your operating system > download > execute the file. Follow the instructions on your computer screen.
Lastly, after the re-install process, try to print again to verify that the problem is fixed.
Sep 06, 2011 | Lexmark X6570 InkJet Printer
Receiving error when attempting to reinstall printer drivers.
Press install the currect printer drivers and drivers path.after add the printer.
Jul 09, 2009 | Lexmark E342n All-In-One Laser Printer
Fatal Error: Loading module SGEDRV.dll failed (Error #126).
Right Click om "My Computer" and select Properties | Advance Tab | Environment Variables.
Select Path Variable in the lower part of the box by clicking on it and add C:\Program Files\Utimaco\Safeguard Easy
Note: To insert ; (semi colon symbol) after the previous path
Thank you
Dion S
May 06, 2009 | Microsoft Windows XP Professional With...
Printer Installation Failed Lexmark Z2320
I 've lexmark printer z2320, and I've download softwer from internet, but after installed, not appear the driver of z2320 but z2300, i want to download the driver propely
Apr 19, 2009 | Lexmark Z2320 InkJet Printer
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Printer Stopped Working - Error 126
Here is a link to microsoft they have a step by step process to try and troubleshoot your problem: http://support.microsoft.com/kb/918730
Aug 25, 2007 | Dell A940 All-In-One InkJet Printer
Fargo Persona  C30 Thermal Card Printer Logo
263 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
pkwc
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
