Question about Keurig Coffee Makers & Espresso Machines
Siemens coffee The nozzle requires replaced as it has broke from threaded area
  • 1,511 Answers
Not good....may need factory service as any pressure on the tubes can also enlarge the port it sits in. Contact 1.866-910-2739 for assistance.
Posted on Jan 31, 2014
Brand new machine, do I need to oil it? singer talent 3321 is suppose to be EASY...needle broke, now it will not sew, seems to be stuck and bobbin seems to not work.
1. You need to remove the bobbin case and adjust the tension. The tension should allow the thread to move with a slight tension. Clean the area with a qtip. The bobbin case sits in a an area that is called the race. The race needs one drop of oil. Replace everything.
2. Replace the needle. Make sure it is in the right direction. Thread the top while the foot is up. If the thread gets stuck while threading there is a problem. The thread should move easily while the foot is up. After you thread the machine except the needle you can put the foot down. Now pull on the thread. It should give you a slight amount of tension. Usually four is a good number. If the tension is too tight you can adjust as needed. Now, thread the needle. Hold the thread under the foot while you turn the hand wheel. The bobbin thread should come up.
3. Give your machine a try with a slow speed.
Mar 25, 2017 | Singer Sewing Machines
Tip
Espresso/coffee not coming out
If you are having a problem with your espresso/coffee machine with water coming out of the nozzle of your espresso/coffee machine or there is a smaller amount of water then usual that you notice coming out of the nozzle area, locate a pin or a sewing needle and clean the nozzle head with the pin or sewing needle. This actually happens due mostly to the grind level of the beans that most people have there unit set on. When you first get your machine there are actually no problems grinding your beans to the finest setting but as time goes on these small grinds end up building up and eventually clogging the nozzle head due to the fineness of the grind and the oil that is found in coffee beans. This also may require more then one cleaning with the pin or sewing needle on the nozzle head depending on how fine the grinds are that you use in your machine. All espresso/coffee machines should have this done often especially if you are used to a finely ground coffee. The simpler solution would be to turn down the grind setting but preferably more people set there unit to the highest grind setting thinking there will be a difference in the taste or strength or robustness of the coffee or espresso. If the beans are not ground at the maximum setting by turning the fineness of the grind down you not only save yourself the amount of time to clean the nozzle head with a pin or needle. You also prevent clogs of this finely ground amount of coffee from backing up in your water path within the unit as well. If the fine grounds are not removed in this manner eventually you can cause damage to the machines water pump as well.
Thanks again
Rick
As you can see from other customers replys this does work very well at alleviating this clog issue in the nozzle head
Click these links
http://www1.fixya.com/support/t10480669-not_come_out
http://www1.fixya.com/support/t10277688-not_getting_thick_plugs_grounds_more
on Sep 24, 2011 | Coffee Makers & Espresso Machines
How to install moen adler thread end nozzle with adaptor
I have encountered different threads in different spouts, both old and new work. Yours may have a thread that is different from the adapter.
Feb 12, 2017 | Moen Plumbing
Model ecc221 coffee maker. Why can't I screw the frother back on?
The tube or the nozzle? If the nozzle is plastic you need to examine the threads to see if they are damaged..
Feb 26, 2016 | DeLonghi Coffee Makers & Espresso Machines
How do i check the pump
  1. The FIRST STEP in diagnosing any heater problem should be checking the output of the air pump. Determine the air pressure required for the heater model that is being tuned. The air pump, in turn, is responsible for fuel delivery.
  2. If you do not know the required pressure look for a decal on the side (usually) of your heater. This decal will state the model number, serial number, fuel capacity, pump pressure, etc.
  3. If your plastic end cover looks like this......
m29609t.jpgM29609 has 2 threaded holes. The hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
or
m16545t.jpgM16545 has 2 threaded holes. The shorter projection with a hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
4. The other hole (longer projection) has a screw with a hole which adjusts a ball and spring relief valve assembly. Carefully adjust the screw until the gauge is reading the pressure level that is specified on the heater's label. If operating properly, the pump should produce more pressure than is required to operate the heater. The relief valve allows the excess air to escape before being sent to the nozzle.
5. Replace plug. Test for leak.
6. If you are unable to reach the desired pressure spray soapy water around the seal of the end cover- at the same time check the plastic cover for a crack. A cracked end cover will not allow the heater to perform properly and will not allow for an accurate reading. The pump must be set at the specified pressure in order to have adequate fuel delivery an adequate fuel atomization. Replace if needed.
7. If you set the pressure to specs and the heater does not perform properly or the cone does not glow a soft red, then check for other fuel delivery problems such as a clogged fuel filter, cracked rubber hose, clogged or worn nozzle, or a cracked nozzle adapter. Soapy water lightly sprayed in these areas will quickly identify the problem most of the time. Any air leak will create problems.
Feb 25, 2015 | Reddy Heating & Cooling
Burns for one or two minutes then stops. also giving a code 3
or
Jan 30, 2014 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Saeco Odea Giro Plus spare parts needed
The coffee dispensing valve is available at your saeco dealer 1-2 hr job to change...
Sep 27, 2009 | Saeco Odea Giro Plus Coffee Maker
Water not getting through
If you look under that white nozzle you will notice a small hole that leads to the drain tray, clean out hole and the area or small enclosure around the white nozzle (clogged with coffee grounds), and make sure that if you pour a little water in that enclosure it goes to the drain tray. That will solve the water under machine problem.
For the amount of water from the coffee nozzle, check brew unit, you will have to remove the shower screen and clean, make sure that the unit is not clogged in one of the tubes.
May 19, 2009 | Solis Master 5000 Espresso Machine
On my Singer Scholastic, the thread jams in the bobbin area
It sounds like it is not threaded properly through the tension disc. Try rethreading and make sure the presser foot lever is in the up position. If it continues, once threaded and with the presser foot down, pull on the thread through the needle. If it has resistance, it is threaded properly. If it pulls easily then there is a problem in the tension area. Check to see if there are peices of thread broke off in between the tension disc.
Feb 06, 2009 | Singer Sewing Machines
Need new steam tube
Try this: http://www.smallappliance.com/product.asp?cur=USD&sid=18954&gid=18960&mid=15&pid=7108&prdCls=P&shopBy=Brand
Jun 16, 2008 | Krups Palatino 905-42 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
