Question about HP Pavilion zd8000 Notebook
WONT BOOT BLACK SCREEN
HP PAVILION dv6000 WILL NOT BOOT. I HAVE REMOVED THE BATTERY, PRESSED THE POWER BUTTON THEN PLUGGED IN CORD WITH NO RESULT. SCREEN IS BLACK ALL KEYBOARD LIGHTS ARE ON BUT STAYS LOCKED.
This is a easy one plug up your unit take out ur battery for 30 sec while holding do the power button hit the power button once again and it should come on and if it dont the great things is there a recall on those pc call hp they will send u a new pc free of charge
Posted on May 22, 2009
When I press the Power the comp is black and tries to boot, the power, charge, and HD LED's are blinking then turn off and repeat again but if i hold the power for about 20-30 seconds released it and...
Hi
Please remove the battery, press and hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON,
Please tell us your results
Good Luck
May 14, 2011 | HP Pavilion dv9310us Notebook
Hi good day my hp tx1120us is booting up with a black screen. what does that mean?
This happens when a memory chip is faulty.
Once thing that does tend to fix this problem is disconnect the power cord, remove the battery, press and hold the power button for 10 full seconds. Than wait 10 seconds, put battery back in and plug in and turn it on.
Jun 30, 2010 | HP Pavilion tx1120us Tablet PC
My hp dv6000 has black screen no sound but the keyboard lights all light up
If mstechwizard's method doesn't work then you will need to reflow the GPU. You can check out www.msbin.com for a diy guide. This is a common "lights on but no body home" issue with this model.
Jun 01, 2010 | HP Pavilion dv6000z Notebook
Hp pavilion dv6000 notebook is not starting after putting into hybernate mode , black screen, all leds on the panel glow, but notebook doesnt boot
Thats the first problem of that model.They first dont want to go out of hybernate mode after that the wifi will not work and after that the video of that computer will be dead.I had like 30 HP Pavilion dv6000 and i just hey them nov but i can repair them.!!!
Nov 10, 2009 | HP Pavilion dv6000z Notebook
MY NOTEBOOK WILL NOT BOOT UP I HAVE A BLACK SCREEN THE BLUE LED LIGHT LIGHT UP BUT THATS IT I HEARD THERE WAS A RECALL ON SOME BATTERYS CAN THAT BE THE PROBLEM?
I have been successful with the following procedure for an HP laptop with a blank (black) screen
1. power off and remove battery
2. press start button for about 35-45 seconds
3. attach power cord (with battery still out)
4. start computer
5. reinstall battery
I have no idea why the problem occurs or why this seems to fix it but it does.
Aug 02, 2009 | HP Pavilion dv6000z Notebook
My battery is at 0% and does not charge and whenever i take out the power chord my computer automatically turns off. Any help
here is a good resource I found:
Solution for HP Pavilion DV6000 Battery Not Charge
  • Reinstalling the power management software has just fixed it for me. Go to device manager and under batteries, unistall the Microsoft ACPI Compliant Control Method Battery. Go to Actions on the menu bar and select ’scan for hardware changes’. It will reinstall it and hopefully start charging immediately (mine did anyway).
  • If your HP Pavillion dv6000 has a battery that won’t charge yet still turns on when plugged in, turn off the laptop and remove the battery then wait for around 30 seconds, re-insert it and turn it back on, the charging update should say, plugged in, charging.
  • I made the bios update, and works for me. My Dv6000 battery problems were fixed. The battery led always blinking every time and the battery didn’t charge. Now it’s ok !
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619
  • If it is still under warranty you can chat with an online hp tech who will check it out over the internet and send you a replacement for free. the dv 6000 laptops have a recall on a few problems and there is a bios update to fix it before it happens but will not correct it after the fact the recall on specific problems extends the warranty to 24 months http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619 should get you to the warranty page.
  • Just got it to charge again.While the laptop is powered and in Windows XP, press and hold the POWER button until it dies. Then, remove the dv6000 laptop battery. Power it back up and enter Windows. Then, re-insert the battery.
  • So I always remove the Hp dv6000 battery after I have powered down the laptop, and I have not had any battery problems since then!
  • I had the same issue my fix was a new cmos battery that was only $10.00 and install updated bios software from HP
  • I had the dv6000 battery problem where it showed my battery NOT CHARGING. I took it apart because my QUICKPLAY would not work either and the QUICKPLAY lights stayed on even after I shut down the laptop. I found that the black ribbon cable on the right (the other looks the same but you can see it is for the power button) was slightly kiltered in the flat socket it goes to underneath the area where the quickplay button is. I straightened it out and made sure it was pushed all the way in and locked and put it all back together and everything worked perfectly after that. About a month before that my POWER and SOUND didn`t work. I did the same thing to fix those problems. MAKE SURE YOU HAVE THOSE CABLES EXACTLY RIGHT in there, IT MAY JUST BE YOUR PROBLEM TOO.
  • Some people dont realise that you should avoid short charges and discharges, if your batery does not go above 40% mabe its charge memory thinks its full. to fix this problem let the batery run fully down, then charge it all the way again. try it a few times if it doesnt work. and you have to go all the way, not let windows go into hibernation. to do that you need to get the batery low, then boot to some boot disk and let it sit till the batery dies.
  • HP has posted BIOS updates to address battery problems as well as the auto startup on some.If you will post the full model number,someone can help you find your driver/updates page.
Hope this helps, please rate! ^_^
Jun 23, 2009 | HP Pavilion dv6000z Notebook
Pavilion dv6000 when power button is pressed,
Have you tried to boot the laptop with the power cable connected? Is the charging indicator on when you connect it to the adapter? If the charging indicator does not light up, check if your adapter output and try booting it with the power cable connected.
Jun 19, 2009 | HP Pavilion dv6000t Notebook
HP dv6000 boot problem
I had a similar problem. You may want to attempt a hard reset on the unit first. This is simply remove power from the laptop. Remove the Battery. With all removed from the laptop...hold the power button down for one minute. Then release the power button. Plug in the battery first...then the power cord. Try powering the unit up again. This reset will not do anything but do a Hard reset on the machine. Sometimes static charge can build up on the motherboard...the PC will go into a sleep protection mode. This essentially wakes it up.
Mar 28, 2008 | HP Pavilion dv6000z Notebook
Hp pavilion dv6000
remove your battery an plug only power adapter.
Mar 16, 2008 | HP Pavilion Notebook
HP Pavilion DV2036e Wont Boot
similar cases,,,,,,,,won't boot,,,,,1.) if with black display; please check your ram memory, if you have 2 take out it all and replace it one by one, try to boot one at a time,,2.) if with black display and the pan start functioning maybe your cpu is dead, try to switch it to another computer with thesame socket and voltage,if this computer won't boot also,maybe you got the answer.........hope to help
Dec 24, 2007 | HP Pavillion ZV6000 Notebook
HP Pavilion zd8000 Notebook Logo
474 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
