Question about Refrigerators
Water dispenser does not work. Please help. - Refrigerators
    Problem Solver:
  • 12 Answers
Regardless of brand the water for the dispenser comes from the valve located at the floor at the back of the refer. The water from the house is connected directly to it and this is probably why you are getting nothing at the door. There are 2 solenoids on it and often one side is bad. You have to change it, no service to it. Good luck, AJ
Posted on May 22, 2009
Ice maker isn't working. Water is not filling the tray but the water dispenser in the door works fine.
could be frozen water fill tube to Icemaker. or solenoid water valve is not opening when ice maker calls for ice. there are 2 separate solenoid valves : one for dispenser another one for ice maker.
Mar 28, 2015 | Refrigerators
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
Samsung side by side fridge freezer with water and ice dispenser the ice dispenser works fine but the water dispenser dose'nt, I have changed the water valve, It worked for a while but its not working now....
You likely have a blockage in the line somewhere. If the water valve is sending water to the icemaker, it should be sending it to the water dispenser.
Try removing the water dispenser line from the water valve and run something through it to try to open it up. I had this problem several years ago and used a length of plastic weedeater line to open it up.
Oct 20, 2009 | Refrigerators
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
Water dispenser not working
I have a Hitachi R-M800GM.
When i operate the water dispenser, water flows out from the dispenser [not strong flow]. There is also water flowing out at the bottom of the freezer door [hinge area]
I think the line running inside the freezer door may have come loose? If so, how to reattach it? Do u have any layout drawings of how the hose is being connected.
Please help.
Thanks,
Rick
May 31, 2009 | Amana ARS2464B Side by Side Refrigerator
See my earlier post of 6-4-09 for the solution to this problem. There is a GE part you can buy the solves the problem. It is part #WR49X10173 -- it's called a "Dispenser Water Tube Heater Kit". The part costs $32-35. GOOD LUCK!!
Apr 12, 2009 | GE GSS25SGPSS Side by Side Refrigerator
The filter you installed was empty, You will need to purge the air from the system. Simply hold a glass in the dispenser with water selected until water flows.
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Amana ARS2464B Side by Side Refrigerator
Refridgerator
please cheak dispenser water pipeline any leakage
Jun 14, 2008 | GE Refrigerators
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
