Question about Bosch Washing Machines
Stacking kit instructions
I am having a replacement Bosch washing machine and need to know how to remove the exististing bosch stacking kit which seperates the washing machine from the dryer above. Note: present stacking kit has pull out shelf.
SOURCE: Bosch washing machines element
depends on model. most washer elements are fixed by a centre nut (10mm)which undo and then prize out the element - takes 5 mins
Posted on Mar 19, 2007
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Posted on Jun 30, 2008
SOURCE: instructions on how to use bosch wff 2001 washing machine
hi if you look on the main bosch web site you can find a list of manuels for bosch washing macine witch are free to down load in pdf format hope this helps tim automan.
Posted on May 23, 2009
  • 456 Answers
SOURCE: Could I "stack" a front
i would not recommend stacking one machine directly on top of another. there are various issues with weight, and movement due to vibration.
what you can do is built a solid "workbench" that you can fit one machine under, and then put the other machine on top of the "bench"
personally i would overbuild the bench, using 2" by 1" wood for the frame, braced and bolted to the wall for stability, and use a 1"thick worktop forv the top of the unit. on the top surface, i would also put a 3/8" wooden beading strip about 1/2" fron the outside edges of the worktop to stop the machine moving with vibration and falling off.
i have done this a number of times when space is limited, although i find it much easier to put tehr dryer on the top as it is the lightest of the 2 units.
hope this helps
Posted on Apr 01, 2011
  • 1705 Answers
SOURCE: can I stack my bosch wfk 2401 on top of my bosch wtl 5400
I wouldn't. Not without a proper shelf for the washer.
Washing machines are heavy because there's a huge lump of concrete placed over the drum to dampen down any vibrations. A tumble dryer is hollow, has little structural strength.
Put the machine on top of the dryer, you're going to get a crushed dryer if not a crushed foot, leg or child. Please be very careful.
Posted on Nov 11, 2011
How do I detach my Bosch drier from yhe stacking kit as I need to replace the drier
most model have some bolts or screws to keep dryer safe on top of washer
just remove bolts and screws and pull back the dryer
Feb 11, 2015 | Bosch Washer And Dryer Stacking Kit...
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
Can I stack a Bosch WTL5400 dryer on top of a Bosch Classixx 7 washing machine?
http://www.bosch-home.co.uk/store/product/Connectionpiece/244024
Call the helpline for verification of compatibility prior to ordering.
Feb 06, 2013 | Bosch Axxis WTL 5400 Dryer
Need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Dec 22, 2012 | Bosch Axxis WFL 2060 Front Load Washer
I need installation instructions for the Bosch Clothes dryer stacking kit.
Just go online and check out support line on manufactures website for instruction
Aug 24, 2011 | Bosch Stacking Kit WTZ11300
Can i stack the Bosch front load washer with a kenmore elite front load dryer
There is no stack kit to do what you propose. That said, you may be able to construct a compartment on top of one unit to accept the other.
Aug 02, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Remove stacking kit from Bosch tumble dryer
I have got the same problem - did you manage to fix it?
Mar 24, 2009 | Bosch WTA4410US Dryer
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
