No heat from air heat unit - Heating & Cooling
    Problem Solver:
  • 17 Answers
Heat pump will only work when outside temperature is above minus 13 celcius or 9 far. Efficiency at lower temperature lower very quickly, spend more energy than what it produce. Good quality machine or option will de-energize outside unit from operating. Wait until exterior temp get warmer and try again.
Posted on Jan 03, 2014
Hi,My remote do not get the good temp in my house. Ex: I set to 80F in heat mode but the thermopump operate slowly and dosn't get hire than 70-72F. The remote see the unit and all. Is the sensor in th
You have a heat pump.
Once the outdoor temperature falls below 36 degrees, heat pumps will sharply lose their ability to heat.
If you are getting a 72 degree indoor temperature when the outdoor temperature is 28-30 degrees, the heat pump is performing up to spec.
On heat pumps, the air coming out of the nearest air vent to the unit should be heated approximately 40 degrees warmer than the air entering the unit.
If you have a 70 degree indoor air temperature, the heat pump should be supplying 110 degree air at the closest air vent to the indoor unit.
Gas heat is a much better heating source where outside temperatures are commonly below 36 degrees.
Even electric furnaces perform better than heat pumps under these conditions.
Nov 30, 2014 | Heating & Cooling
Tip
KNOWING ABOUT CONDENSER
What is a condenser?
Is a device or unit used to condense vapor into liquid. A condenser is simply one component of an air conditioner. Whether you have an outdoor air conditioner or a window unit air conditioner your air conditioner contains a condenser.
Condensers are used in outdoor air conditioning systems as well as heat pump systems. Condensers in an air conditioning unit have very few controls. They will have an on and off switch. Occasionally these air conditioners will also have a brown out option. This option shuts down the compressor when the electrical current is low.
A condenser is simply a heat exchanger. It compresses refrigerants into a hot gas to then condense them into a liquid. A condenser is a major component in a air conditioning or heat pump unit. It moves air across the coils to facilitate the transfer of heat.
In a heat pump unit the condenser has a few more features. It will have a reverse valve that allows the unit to switch back and forth between air conditioning and heating. Even when the unit is heating, it uses the condenser for defrosting the coils. If the coils become layered with frost it will effect the units effectiveness this is defrosted when the reverse valve switches to air conditioning mode to move the hot gases through the coils melting the built up ice. It will automatically switch back to heating mode once the ice is cleared to once again heat the home.
To keep your unit in good operating condition it is vital to keep the area around the condenser clear of all debris as well as keeping the filter clear of dust and dirt. A clean machine makes a happy machine. A happy machine will keep you cool during the summer months and warm during the cold months. It is suggested to change the units filters when they become dirty, depending on your area and conditions near your home this may be as often as once a month or as seldom as every 3 to 6 months. You will have to pay close attention to your units needs to decide the right time to change or clean your unit’s filters.
It is very important no matter what type of unit you have to prevent the blockage of the condenser. If the condenser becomes block it can effect the units efficiency or even cause the until to completely fail. For this reason it is one of the most important components of a cooling or heating system. A condenser allows the maximum airflow to the unit.
Keeping you condenser in good running condition will not only prolong the life of your heat or cooling system but also provide you with the most efficient heat and cooling system saving you money on heat and cooling.www.victorwod1234.blogspot.com
on Apr 08, 2010 | Heating & Cooling
Is it normal operation for these units to EVER blow out cold air or "nonheated" air when unit is in heat mode?
Yes. Heat pumps have to go into defrost just like a freezer when the temp gets too cold outside. The heat pump will temper the indoor air electric heat.
Apr 12, 2010 | Amana PTH123B25AJ Heat Pump Air...
We have an air make up unit on our community hall with no heat
Depending on the outdoor temps, 10 kw won't heat much. If you have a multi-meter you can check the amp draw as well. You should get 20 amps for each heat strip. Each heat strip is 5kw.
Mar 23, 2010 | GE Built-In Room Air Heat Cool Air...
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
HEATER ISNT HEATING UP THE ROOM ENOUGH
It sounds like the space is too large for the BTU capacity output of the unit.
Did the unit ever heat the space?
Have you measured the temperature of the incoming air, vs the discharged air?
And finally, based on the Model number in the heading of this thread, this unit is cooling only, no heating (it's not a heat pump).
Jan 11, 2009 | GE AJCQ08ACB Air Conditioner
Blows cool air
This is normal. To maximize the units efficiency the fan continues to run until all the heat from the coil is pasted to the circulating air.
May 24, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heat...
It sounds like the thermostat bulb has moved or the unit is getting an immediate air recirculation due to a partial blockage or air diversion close to the unit causing the warm air to get back to the thermostat bulb too soon, heating only a very small area.
srich
Jan 06, 2008 | Amana PTC153B35AE Air Conditioner
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
Heater!!!
I am experiencing a similar problem with my Mitsubishi slimline MSH09TW unit; about 4 years old; It use to give us very hot air now it is giving some what hot air; northeastern USA current temperature about 15F. You think frigid weather in Cranbury NJ could be responsible or some thing else is going on. Please help me if you have some time and knowledge about Mitsubishi heat pumps. Sincerely, DSS
Oct 31, 2006 | Mitsubishi MS12TN Air Conditioner
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
