Question about Vehicle Parts & Accessories
Astra faults ive replace the fan controls under the radio for new and checked all fuses what can i try next
  • Alan Springett Jan 05, 2014
    Hi luke blake, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Novelist:
  • 114 Answers
Luke why have you replaced switch what is the problem?
Posted on Jan 05, 2014
Vauxhall astra 1.7 code fault ecn 189554 going into limp mode
P1895 = Limp home mode - Limited performance
P1481 = Fan Control Circuit 1 - Open Circuit
P1482 = Fan Control Circuit 2 - Open Circuit
it could be there is an issue with the cooling fans on the vehicle, and the ECU is going into limp mode to prevent the engine overheating, or because the coolant temp is getting too high.
First, check all fuses are present and not blown.
Aug 28, 2013 | Cars & Trucks
I have a 1998 toyota corolla ve with electrical problems first it was the dome light the the dome,radio,clock, and cig lighter now its just the clock,radio, and cig lighter I checked all fuses they we
check the fuses again, sometimes they blow right after you install them.
there may be a short in the wiring causing them to pop.
check fuses again and let me know
Dec 11, 2012 | 1998 Toyota Corolla Sedan
Driving down road I suddenly lost all head lights dash lights, gauges, fan , and radio. Had to drive to work in dark with only maker lights. Now car runs like ****. when it starts up after sitting all
Well everything but the headlights are controlled by the ignition switch so it must be something before the key switch. So I would look at the major fuses not the small ones. There may be a broken wire or connection between the battery and the fuse box.
Sep 21, 2012 | 2000 Ford Focus
The location of the radio fuse for a 1996 jag xj6
Check the fuse box in the trunk next to the battery.
let me know if you find it.
Aug 09, 2012 | 1994 Jaguar XJ6
2003 chevy silverado air does not blow through vents. Condenser works. Pipes are cold. Fan works. Modular (next to fan) repalced to get fan to work. Heater air conditioner controls under radio replaced....
The air vents are control by vacuum line and or linkage.
Listen for hiss or feel for vacuum leak under the dash,
Feel for broken linkage(s) that are close to the vents.
WORK BACKWARD if you have small hands to feel out where is the missing link.
Jul 15, 2009 | 2003 Chevrolet Silverado 1500
05 astra air con fault
Hi there. The compressor will not come on unless the system is charged. There is a "low limit switch" which controls the engage voltage on the low side receiver. No charge, no engage.
Thanks
Paul
Jul 11, 2009 | Heating & Cooling
2003 ford escape, fuse keeps blowing for door locks, radio and dome light. y
check for a shorted to ground positive wire repair as nesseacry
Jun 01, 2009 | 2003 Ford Escape
Radio doesn't work and I think it's a fuse but have no manual (1994 Jaguar XJ6) so don't know which fuse to check.
The fuses for the radio/cd player and all other audio devices are in the rear fuse box located in the trunk area.
Apr 08, 2009 | 1994 Jaguar XJ6
Vauxhall astra radio keeps switching on and off on its own
I had this problem for the last 2 weeks, didn't think much of it, but recently the car radio just turned on and off by itself, it decided to do so whilst the car was switched off and it drained my battery. After doing some tests with the Amp meter and removing the fuses for the radio and infotainment system the amps going through the batter went from about 0.7 to 0.001 (far more accpetable) - so the radio was draining the battery and randomly turning itself on/changing stations and the internal display system had stopped working.
after putting the fuses back in and re-testing the radio worked fine (almost like it had a full reset - no random turning on and off OR changing of radio stations)
the fuse box for my astra was next to the battery under the bonnet (see your car manual - I had lost mine so googled for it)
http://pdfcast.org/pdf/2006-vauxhall-astra-owners-manual-operation-safety-and-maintenance
PAGE (267 or 265)
but it seems yanking the fuses for the radio (FUSE number 35 and 36) seemed to fix it (been a few days and no flat battery) -
It maybe an intermitent fault, in which case i'll have it looked into, but as garages charge an arm and a leg i'd give this solution a go and if your battery is good all you need to do is remove the fuses and put them back after say a minute or so)
Jun 24, 2008 | Audio Players & Recorders
Vehicle Parts & Accessories Logo
239 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
