Question about Plumbing
Basket strainer renewal - Plumbing
  • 2712 Answers
SOURCE: Basket Strainer Specs Question
1\ Amount of free open area is the ratio of the open area through the strainer basket to the cross sectional area of the pipe. A good basket strainer should have a ratio of 4 to 1. 2\ Ease of basket removal is important because baskets may require frequent cleaning or replacing due to buildup. 3\ Compactness of the design saves you valuable space. A small strainer is less bulky and easier to handle. 4\ Availability of basket perforation sizes gives the strainers the flexibility to cope with a wide range of particle sizes.
Posted on Aug 27, 2008
  • 2712 Answers
SOURCE: How to Clean Pump Strainer basket
Turn the swimming pool pump off and wait for the water to drain from the strainer basket. You want to make sure that the pump is completely off before you proceed. Remove the screws or any items securing the lid of the strainer basket. Open the lid and pull out the strainer basket. Vacuum the strainer basket or scoop out any debris. You may want to run clear water through the basket to ensure you removed all debris. Feel toward the impeller and remove any clogs or obstructions preventing the impeller from working properly. Check the o-ring under the cover of the pump strainer housing. You may need to use a silicon lubricant to ensure a water-tight seal. Put the strainer basket back into the pump strainer housing and pour some water into the basket. Replace the lid and secure it in place. Turn the swimming pool pump on and check for proper pressure. If your pressure doesn't register, you may need to troubleshoot to find the problem.
  • 49 Answers
SOURCE: Gap between basket & body of basket strainer
can you clarify that, i am not sure what part of a basket strainer dimension you are refering to. the dimensions of a basket strainer are related to the standards of the fixtures they are installed on. It has to be designed to work on different thickness of materials; thick materials such as cast iron or marble and thin materials like stainless steal and pressed steal. I have experiensed some strainers that do not meet this and are not deep enough to fit thick materials o r do not tighten enough to handle then materials.
Posted on Jan 23, 2009
  • 11 Answers
SOURCE: peeling paint coming off of oil rubbed bronze basket strainer
Bronze is more expensive than standard mass production is worth, i supposed if you want them made out of any mat. you can call kohler and pay for it, i've been to their plant and they do some pretty awsome custom work.
Rubbed oil is just a color and somtimes "you get what you pay for" if you buy a cheap basket strainer they usually do exactly what you're saying.
You can buy more expensive strainers that have a better finish, I know Kohler and Moen have lifetime warranty finish on many of their higher end products.
Posted on Jun 06, 2009
  • 21 Answers
SOURCE: How do I know which Garvin Basket Strainer to
I would suggest you replace the entire basket strainer. I can honestly say that in 30 years I have never seen two that were alike.
Posted on Nov 27, 2009
What is the difference between standard strainer and strainer for food erator? I bought a replacement sink wiht standard strainer, which does not seems to fit garbage disposal
If you need new sink strainer basket for disposal side of sink, you have to buy new disposal.
Each garbage disposal comes with its own strainer basket so that disposal can connect and seal.
First, the disposal strainer basket is installed, and then disposal lifts up and attaches from below.
A rubber gasket comes with new disposal.
Rubber gasket fits between disposal and strainer basket so that disposal seals correctly.
Photo below shows how disposal connects to strainer basket using steel connector ring under the sink.
I wrote tips for installing a disposal from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 16, 2011 | Franke 900 Black Basket Strainer 900
We are installing a new undermount sink. Is it best to use standard strainers or basket strainers?
If you have a garbage disposal, use standard strainers, but depending what may go down if not, such as hair, fiberous material that will get stuck in grease, then use the basket strainers.
Jan 22, 2011 | Plumbing
Strainer lower washer,not basket strainer, do you have source?
Not sure what you are asking. If it is broken it can be replaced, any hardware store would carry it. If it is leaking, try using plumbers putty. Roll it between your hands like play-dough. Roll it into long skinny string about a pencil width, and place it under the lip of the basket strainer where it makes contact with the inside of the sink. Proceed to tighten from underneath. Keep the basket strainer as still as you can. Remove excess putty.
Mar 17, 2010 | Danco Bg/10: Sink Strainer Washer
Basket strainer
You will need to have the entire basket strainer drain assembly replaced.
Jul 12, 2009 | Plumb Pak Laundry Tub Strainer Basket...
Peeling paint coming off of oil rubbed bronze basket strainer
Mar 03, 2009 | Mountain Plumbing Mountain Basket Strainer...
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Jan 28, 2009 | Plumbing
Jan 20, 2009 | Elements Of Design Plumbing
Aug 27, 2008 | Belle Foret Accessories NBBS2-TB Tumbled...
Aug 27, 2008 | Moen 22174 Stainless Steel 2in. Basket...
Plumbing Logo
142 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
