Question about Kenmore Elite 45986 Front Load Washer
The washer will not spin
The washer will turn on, but will not spin. It does fill with water.
    Sergeant:
  • 187 Answers
  • Hi
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
Posted on May 22, 2009
Hello. I have a Amana top laod washer. My washer will spin(i can hear it spin and see it shakes as it spin). My washer will not fill with water when I turn it to a washer cycle. No water will fill in this...
If you're not getting any water (hot or cold), you'll need to check voltage coming to the solenoid valve. This is the valve the hoses connect to on the back of the washer. If you're not getting voltage during the fill cycle, your timer is the most likely culprit.
Jan 01, 2018 | Amana Washing Machines
Washer is working during spin, meaning it's still
Hi, a Kenmore washer that is not filling with water may have clogged inlet screens. Place a bucket underneath the hoses to catch any leftover water. Unplug the washer and turn off the water supply. Remove the water hoses from the back of the washer and inspect the screens inside the inlet ports. Often, these clog with sediment. Clean the screens with a small toothbrush. After cleaning, reattach the hoses and turn the water supply and power back on.
Another reason the washer might not fill is something interfering with the water pump. Check the connecting hoses on the water pump to make sure they are not clogged. With the hoses disconnected, check the water pump for obstructions.
Jun 19, 2011 | Kenmore 24722 Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer will fill up with water but will only spin
is it noisey on spin? sounds like control board to me. try this , open door and turn steel bowl by hand, left then right. if u can turn the bowl in both directions it is not the bearings. please reply 4 more help.the bowl should turn free in both directions.
Apr 14, 2010 | LG WM-1832C Front Load Washer
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Cold water will not shut off at end of spin cycle
electriic inlet valve is obstructed, try removing cold water hose direct the hose into a bucket and fill the tub on the warm setting (flushing the cold valve) then try the washer again ..If that doesn't work a new valve is needed
Dec 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Elite 45986 Front Load Washer Logo
131 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
