Question about Supersonic SC-72JB - 7 MID w Android OS
Screen is locked theres no volume button to reset
Don't have the password just purchased it at pawn shop how can I reset it? I've tried reset THe only volume button is on screen HELP!!!
Trying to reset a tablet, when I hit the power and home button, it says there's no drive
Do as you typed also hold the volume button down letting the power button go when you see the screen come on.
Mar 09, 2016 | Tablets & eReaders
How can I reset my tablet?
    1. Here's how to execute a factory reset:
      1. Turn your tablet off and remove the SD card, if there is one.
      2. Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
      Forgot your tablet's password? - TechAdvisory.org
      www.techadvisory.org/2013/03/forgot-your-tablets-password/
    Feedback
  1. Forgotten Pattern, PIN or Password on an Android device
    acer.custhelp.com/.../forgotten-pattern,-pin-or-password-on-an-android-...
    What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
Nov 29, 2015 | Tablets & eReaders
I purchased my tablet from a pawn shop yesterday and don't know how to hard reset it due to there being a lock pattern on it and don't know the g mail account associated with it
1) Power down your tablet.
2) Tap the power-on button and volume down button at the same time
3) Tap and hold the power-on and volume down buttons until you see the android alien icon
4) tap the power-on and volume up again at the same time until you see the System recovery menu.
Android System recovery menu
Volume up/down to move highlight;
power button to select.
Options are below
reboot system now
apply update from /sdcard
wipe data/factory reset
wipe cache partition
recovery system from backup
update rk image from /sdcard
select (wipe data/factory reset) bush pushing the power button to select it and restart the device after.
Oct 17, 2015 | Dragon Touch Touch R10 10.1 Google Android...
How i unlock password
Do you have access to another computer? You can use your Google account to remotely reset it.
There is also some not too expensive Apps that work.
I am having a hard time figuring out if there is a mechanical reset or not. I need to know more about the unit you have as IRULU has five different models of the 9" and most models come in 5 different varieties.
If there is a mechanical reset, sometimes it is volume push up and power, sometimes it is power/home button as the back/select button.
Below are some links you may find helpful also. I can help more if I know more about your tablet.
Hope to hear from you soon.
Philip
Android Jelly Bean Screen Lock Password Unlock
How to unlock an Android phone tablet
or if you are technical
39 lock screen 39 tag wiki
Feb 04, 2015 | Irulu 9 inch Android Tablet PC, 4.2.2...
How to restart my tablet without turning it on because I forgot my password?
Look in your tablet instruction book for a procedure called 'hard reset' or a location for a small hole on the edge or back of the tablet where you can push in something non-conductive, like a toothpick to press a hidden reset switch. Without having a make and model for your tablet, it is hard to determine what exactly to do because each make and model is different. You talk about pressing the power and low volume buttons- are you holding them both in simultaneously for 10 seconds? This might be the reset procedure for your tablet, but that is not clear. One last thing to try is to hold in the power button for 10 seconds and see if you get a power off screen. If you get this, try powering off the tablet and then restarting. Also make sure the keyboard isn't on caps lock when you type your password.
Jan 03, 2015 | Tagital Taital TM 7" Android 4.0 4B MID...
How do I recover my lock screen password for my tabeo tablet
Not possible to recover your password just factory reset back to when new! Press power for 30 seconds then press power and volume+ buttons together until reset screen comes on then move to factory reset option using volume buttons and select using power button!
Dec 26, 2014 | Toys R Us Tabeo
How to reset a zeki tablet password
Hello there,
From the Zeki website it says do this.
If you have set the screen lock to a password or pin code, and have forgotten the code; you will need to reset you tablet to factory default setting.
  1. Make sure your tablet has a full charge
  2. Press and hold the Volume - button and tap the Reset button
    (The reset button is located between the HDMI and USB ports)
  3. Continue holding the Volume - button until the boot screen appears
  4. Release the Volume - button
  5. Use the volume controls to navigate to "Wipe data/Factory reset"
  6. Press the power button to select
  7. Navigate to "Delete all user date"
  8. Press the power button to select
Your table will take several minutes to reboot to a factory default setting.
Hop this helps you friend. :)
Sep 25, 2014 | Digital Products International Zeki 7
Locked out of my Kids Tablet 7 inch touch screen Android 4.1
You did try to hold vol+ while powering on, and keep on holding vol+ until you get the menu?
Jan 06, 2014 | Curtis Klu 7-inch Touch Screen Mobile...
Supersonic SC-72JB - 7 MID w Android OS Logo
54 people viewed this question
Top Supersonic Tablets & eReaders Experts
Paul Bade
alibaba69
Are you a Supersonic Tablet and eReader Expert? Answer questions, earn points and help others
