Question about GE Dehumidifiers
Manual for rhino rd4s
I have got a dehumidifier Rhino RD4S. But I haven't got a manual for it.Do you know where I can get it?
Haier 45-pint dehumidifier unit cannot be turned on. It has been running fine last few days.
The first thing that comes to mind, is have you emptied the water collection bucket recently? If so, be sure that the bucket was properly reinstalled and is making contact with the bucket safety removal switch.
If you haven't emptied the bucket in the past few days, it may simply be full and will not start until it's emptied.
Hope this helped you and thanks for choosing FixYa.
Sep 13, 2011 | Haier 45-Pint Dehumidifier
I dont know how to work my dehumidifier its haier hdn455 i dont know where the manuel is
Lament no longer. The link below is to your Owner's Manual. You can download and print it for future reference.
http://www.managemylife.com/mmh/owner_manuals/19991/HAIER-Dehumidifier-L0522296
Hope this helps to you get it up and running.
Jul 13, 2011 | Haier HDN455 Dehumidifier
Whirlpool Gold Dehumidifier -The lights are all working, no fan? Is there a reset ?
You have what Whirlpool calls a Type 3 Control Panel. If you don't have the unit operating in Continuous Mode, the fan will operate only, when the compressor turns on to extract the humidity, based on the level of extraction you have it set on. If you haven't already,.set the control on Maximum and Continuous Mode.
If that doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. After the time has elapsed plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, the 15 minute timeout, allowed the unit to reset itself and revert back to the original factory settings. If so, you can set the controls as you like.
To further assist you, I have an included a link to your Owner's Manual, in case you have misplaced your. You can download and print it for future reference.
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%201188826.pdf
I hope this helps you to further troubleshoot and solve the problem. Please let me know. Thanks.
Jun 21, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
The dehumidifier runs, cycles on and off, but there is almost no water in the receptacle. I haven't had to empty it since it started cycling on & off this season. I usually have to empty it at...
You may have the humidity setting to high. Try lowering it to 45%. Or if yours doesn't have an LED Screen, set it for minimum. Also, check and clean the air intake filter, if you haven't already. Keep in mind, most dehumidifiers have a fan that may seem to run constantly, but the compressor doesn't turn ON. The fan is circulating air, in a effort to detect humidity levels that are higher than what you have the humidity removal set on.
Hope this helped you.
May 10, 2011 | LG LHD45EL Dehumidifier
Motor runs, but dehumidifier does not collect water
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. The fan running, may be the automatic defrost cycle, that defrost the coils, if they become frosted over. The defrost cycle, depending on the unit and how is was designed, can last any where from 15 minutes up to 45 minutes.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filter on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Whirlpool Dehumidifiers
Of our three 54501 Kenmore dehumidifiers, none produced water after two - three weeks. They run but no humidity is drawn out of the air.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. I find it uncanny, that all 3 units are not collecting any water. So, it may simply be the case, that the humidity level on each unit is improperly set.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filters on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
May 03, 2011 | Kenmore 54501 Dehumidifier
I have one of your dehumidifiers and it turns on but we do not get any water out of it I have had for a few years but it was only used one year and it worked great when we went to use it again we got no...
If you haven't clean the air intake filter since you've had it. More than likely that's the problem. A dirty filter makes the dehumidifier strain to take in the moist air and it just can't keep up.
If you don't have your Owners Manual to guide you through the process. You can download one online, from Sears Parts Central.
Apr 27, 2011 | Kenmore 54501 Dehumidifier
I have a Kenmore 58054701700 Dehumidifier and the unit is leaking all over the floor. We have hard water and there is an accumulation of calcium on the bottom of the bucket. Could this be the problem?
I'm not sure how hard tap water would affect a dehumidifier. Since you're not collecting the tap water.
More than likely, the problem is a result of a clogged drain hole or drain tube that fills the bucket. To unclog it get an 18" long plastic Zip Tie, that is small enough to fit into the drain hole or tube. Carefully thread it into the hole and push it in as far as you can. You will reach a bend in the tubing, so gingerly work it past the bend. Once you have inserted the Zip Tie as far as it will allow, slowly pull it out while rotating it. Be prepared for water to follow. In addition, if you haven't clean the filter recently, now would be a good time to do it. Remember to turn OFF and unplug the unit, before attempting any repairs.
Hope this helps you solve the problem. Please let me know. Thanks.
Apr 25, 2011 | Kenmore 54701 Dehumidifier
How can I get a manual for the LG LD65 EL dehumidifier? Need to know how to maintain it.
Try: http://tinyurl.com/LD65EL
I downloaded Djvue reader but still couldn't downlaod the manual.
Dec 18, 2009 | LG LD65EL Dehumidifier
My dehumidifier does not come on automatically.
Power button on mne is on the far left of the control panel.
Jan 17, 2009 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
414 people viewed this question
Top GE Dehumidifiers Experts
J.D. Browning
J.D. Browning
AZBen
AZBen
Are you a GE Dehumidifier Expert? Answer questions, earn points and help others
