Question about HP Compaq Presario SR1430NX (PS566AA) PC Desktop
I had a problem recovering my computer. I bought recovery disks from compaq. 4 hours into I got a message Can not copy X:\WINDOW\1386\LANG\IMJPCL\HL_. Can I fix this? If it is possible great I will pa
My computer crashed. I put in recovery disks 4 hours to get to disk 7 at 92% I got an error message Can not copy X:\WINDOW\1386\LANG\IMJPCL\HL_! I tried to reenter then I had to ignore. It then would not start
  • HP Master
  • 2,404 Answers
Sounds to me like the hard drive has bad sectors on it and it can't copy all the files to it. Also its taking way way to long to recover, shouldn't take that many hours to recover the computer with the disks.
Its taking to long to copy and verify the information to the hard drive. Get the hard drive replaced with a new one or a known good used one.
Posted on May 22, 2009
My compaq presario cq56 does not have a recovery system
try using boot recovery disk that u should have made when u setup youre computer ps set bios to boot cd or dvd rom and save
or try f8 in recovery mode and try it that way if not u could try the manufactures for a recovery disk or purchase a new copy of windows or try a linux boot disk maybe use full thanks
Apr 05, 2014 | Compaq Presario CQ56-115DX Laptop
Compaq startup ask to insert media disk
remove any pen drive or dvd disk or cd from the computer then restart the computer
Jan 17, 2013 | Compaq Computers & Internet
My computer COMPAQ ARMADA M300 show this message: PXE-E61, and then Window XP star but after this do nothing.
You should follow the below steps sequentially in order to isolate the cause and solve the issue:
  • Verify all the cable connections of the hard disk. An improper or loose connection is likely to be the reason, in case the hard disk has been recently installed or moved.
  • Check if no other storage device is connected to the computer. If it is, remove it.
  • Enter the BIOS setup when trying to start the computer and see if hard disk has been correctly setup and detected in BIOS. If the hard disk cannot be detected due to any reason, you should consider the next suggestion as it might be physical failure.
  • Replace the hard disk and restore the data, provided a good backup is available. In other circumstances, you should consult a company that provides data recovery services. These companies have efficient tools and staff to perform hard disk recovery and extract valuable data securely.
Wish you luck,
Lucas
Jul 08, 2011 | Compaq Armada M300 Notebook
I have archos 504 160 gb when it turn on i have message (recovery code 4) would you like to recover your system ? no - repair disk - format disk when i push no no thing action . when push repair or...
This is a recovery mode, and this menu allows you to:
-Format your hard drive
-Restore your system
In case of repair disk is selected :
For the first step you have to go on our website, and download the latest firmware update for your product.
Plug your Archos 504/604 on the computer and copy the firmware previously downloaded at the root of your device.
Disconnect your device as usual, and select done on the screen.
You have to plug the dc adaptor to update successfully, press a button to reboot your device.here is the web address  http://www.archos.com/support/support_tech/updates.html?country=us&lang=en&#firm
Nov 27, 2010 | Archos 504 500870 Digital Media Player
The file c:\1386\ADSLDP.DL_ cannot be recovered!
Alright if I were you i would say Reinstall Windows and your file should be back that is one of the probably way you could do.
Dec 15, 2008 | Gateway GT5220 PC Desktop
My gateway notebook, model MX6960 will not boot up. on screen recommendation was to use system recovery disc.It gets as far as copying files 3% then message appears: The...
Check to make sure there isn't any foreign material or heavy scratches on the disc. If neither of these aplly I would try contacting gateway for another set of discs.
Dec 09, 2008 | Gateway Computers & Internet
Can't get NEC Litepad to recognize new Toshiba 1.8" MK2004GAL
I've read on other web forums that the recover disk only works with the original drive partiions. There's a hidden partition on the original drive that the recover disk uses to install the OS (maybe other software too). You'll need to clone/copy the original disk partitions to the new hard drives and then you'll be able to use the recovery disk.
Nov 28, 2008 | NEC Versa LitePad PC Notebook
Can't extract files on System Recovery Disc 4 for Compaq Presario model 6350US
At this point, you can try to clean your disk # 4 and see what happen,
or try to make a copy of disk # 4 (if you can copy the disk) and try again.
or
1) Contact your customer support and ask for a new set of disks.(or only # 4)
or
2) Boot your computer with another OS disk (win XP)
or
3) Boot your computer with some utility disk
Oct 19, 2008 | Gateway MX6421 Notebook
Factory settings
I find that your notebook is shipped with Operating System disk and Application and Driver recovery disk.
The steps to reinstall the OS using the OS disk are available in the link provided below :
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00681978&dlc=en&lc=en&jumpid=reg_R1002_USEN
Instructions about reinstalling preinstalled Applications and Drivers are provided in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00400062&lc=en&cc=us&rule=23097&dlc=en&product=1144546
Reinstalling the OS using Recovery manager if your Notebook is shipped with one.
1. Click Start.
2. Select "All Programs".
3. Select the "System Recovery" option.
4. Select the "PC Recovery" option.
5. This will open a new window with the options "Microsoft system restore" and "PC Recovery".
6. Select the "PC Recovery" option and Click next.
7. Now you see the Windows XP LOGO with Please wait...... message
8. Welcome to PC Recovery screen will appear Click OK
9. Click Next.
10.Then you can see the option " The PC Recovery was sucessfully completed Click Restart to restart the PC or Click Turn off to turn off the Notebook"
11. Click Restart.
Steps to Recover the Notebook from a set of Recovery Disks:
1. As soon as you boot the Notebook with the recovery Disks we can see the following 3 options:
i) Click R for Standard PC Recovery options
ii) Press 'F' to format the Hard Drive and reinstall the original factory settings (All data will be lost)
iii) Press Q to quit this menu
2. Press F.
3. Press Y.
4. Welcome to PC Recovery window will appear Click OK
5. The recovery process will be started and the process will prompt to insert the next recovery disk. Please insert the next recovery disk when prompted.
6. Please insert the recovery disk whenever prompted for and click oK.
7. The message "The PC Recovery is complete sucessfull" will appear.
8. Click Restart to restart the Notebook or Click Turn off to turn off the Notebook.
This will complete the recover process using the set of recovery disks
Aug 09, 2008 | HP Compaq Presario V2000 Notebook
Need to restore my evo n600c laptop to factory settings i have no recovery disc
If you need to recover your computer you will need the disk, otherwise a copy of windows to restore. The question is why do you need to recover, and whether you can go to safe mode and restore system to it's original functionality without recovery disk?
Also are you trying to recovery bios settings?
Depending on the extent of your computer recovery. Can you still get into the computer, into windows desktop? You might need to format and reinstall all drivers and programs
If you decide on formatting I have gone to the HP.com for all your drivers, as Compaq and HP are one company now. You can get a copy of all you drivers from the link below, just click on windows your using and then a list of all drivers are ready for your downloading. As you download save them to computer, once completed download, go to your folder where you saved files and run each one until you have everything installed
tp://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316675&lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=316673
Aug 03, 2008 | Compaq Computers & Internet
HP Compaq Presario SR1430NX (PS566AA) PC Desktop Logo
97 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
