Question about Stihl Garden
Echo chainsaw points gap
What is the point Gap for stihl 056 chain saw
  • 486 Answers
.012"
Posted on Jan 30, 2017
  • 76 Answers
SOURCE: please advise oil/petrol ratio...air gap ...plug
Hi
follow the link there are several manuals there for Echo chain saws
http://lawnandgarden.owneriq.net/manuals/mfg/echo/echo_chainsaw_product_list.html
http://www.echo-usa.com/pdf/documentation/CS300034003450efT1E_060402_1.pdf
on page 4 it says the types of oil and petrol
hope it helps
appreciate some rating form you.
thanks
Posted on Jul 18, 2009
dontbother10
  • 2220 Answers
SOURCE: points gap for a McCulloch 7/10
0.019 - 0.020 in according to this:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/61f60e13d19afbf288256b62001a10e6?OpenDocument
HTH
Lou
Posted on Sep 24, 2009
dontbother10
  • 2220 Answers
SOURCE: magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 22, 2010
  • 4088 Answers
SOURCE: what is the spark plug gap setting for small ECHO
0.020" should work well. Check the quality of the spark--it should be blue and snappy with the new plug. Hope this helps!
Posted on Dec 10, 2010
  • 95 Answers
SOURCE: what is the gap for
The easy way is to put a piece of sand paper between the coil and magnet.Put it in tighten the coil and pull out the paper.
Posted on Mar 08, 2011
How do I get a repair,parts manual for 056 stihl
  1. Dealer only information
  2. Unit Technical manual NLA
  3. Unit parts becoming scarce
Feb 14, 2015 | Stihl Chainsaw 045 056 Clutch Chain Saw...
Spark plug Gap, Stihl o26, chain saw
These things may be found on Stihl's website. Accordingly it says the spark plug gap should be 0.020". You may also download or request a hard copy of a manual for your saw at the same site.
Oct 08, 2014 | Garden
Magneto specs stihl 170
There is only an ignition module on this saw which should be fitted at a maximum of 0.5mm from the flywheel.
Apr 15, 2013 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Need plug gap for echo cs 351 vl
Recommended plug is NGK BM-6A gap .024" to .028"
Apr 05, 2013 | Echo Cs-351vl Chainsaw Parts Manual Chain...
Air gap and spark plug gap 025stihl chain saw
the air gap is about a business card thick and the plug gap is .020. Stihl has a special tool to measure exact air gaps so the business card is close
Mar 20, 2013 | Stihl Garden
Can you tell me what my stihl chainsaw ignition point gap should be when the case says 045AV and the literature I find says that this has an electronic ignition (magneto) and the literature says breaker...
Go to arboristsite.com.They can tell you everything you could ever need to know about that saw.You do need to sign up.Its free to do so.I am sorry I just don't the gap off hand.But they will help you with the carb and any other problem FREE!!!
Mar 16, 2011 | Stihl Chainsaw 045 056 Clutch Chain Saw...
What should the coil gap be on a stihl 034 chainsaw
the coil gap on that saw is 10-15 thousandths
find parts and details about Stihl at dealers like www.arcolawn.com
Joe
Jan 01, 2011 | Standard Oregon Chainsaw Chain For Stihl...
Need to know the oil to gas ratio for a 056 stihl chainsaw?
Stihl chainsaws are 1:50 oil to gas ratio. Make sure you use good high-quality 2-stroke oil, preferably that which is made by Stihl.
May 21, 2010 | Stihl Chainsaw 045 056 Clutch Chain Saw...
Whatb is the gap for points on an 028wb saw
Stihl 028 OM can be downloaded here:
Stihl Product Instruction Manuals
http://www.stihlusa.com/stihl_ownersmanuals/STIHL028_with_safety_manual.pdf
If equipped with points 0.015" ± 0.001".
Lou
Mar 03, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Please advise oil/petrol ratio...air gap ...plug
Hi
hope it helps
thanks
Jul 18, 2009 | Echo Garden
Garden Logo
193 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
