Question about Samsung HP-R5072 50 in. Plasma HDTV
Tv going on and off - Samsung HP-R5072 50 in. Plasma HDTV
Entering activation code into fire tv
To activate HBO GO on your Amazon Fire TV or Fire TV Stick:
  1. Download the HBO GO app on your Amazon Fire TV.
  2. Open HBO GO on your Fire TV.
  3. Choose Activate Your Device to get your activation code. ...
  4. On your computer, go to HBOGO.com/activate.
  5. Choose Amazon Fire TV and then Continue.
Jul 29, 2016 | Amazon Fire TV
Program direct tv remote o sanyo tv
press menu button, go down to parental,fav's & setup push select button,....go down to system setup push select button...go down to remote push select button...pick av1,av2,or tv press select button...pick tv press select...go down to sanyo and press select it will tell you what to do from there
Aug 10, 2014 | Sanyo DS32920 32" TV
Tv is on but no sound. Its not muted and volume is turned up
Tries tv and those cables or dishes boxes unplug,replug it back like about an hour later.For those pay boxes to reboot and upgrading it softwares.The tv to do a whole tv set resetting it self back to the factory setting.Than go into the tv Menu Setting to go to the tv Audio Setting.Go down to do a audio resetting again for the Audio Setting to go back to factory setting.These steps will help and have a great chances to get ur tv audio back.
Jun 25, 2011 | Olevia LT32HVM 32 in. LCD Television
Pioneer pdp 507cmx has no sound does this tv have speakers
Yes,every tvs have a basic pair of speakers.Tries tv unplug,replug it back like about an hour later.Go into the tv Menu go to PICTUTRE SETTING go down to do a resetting for a back to factory setting of the whole tv main Tuner signal board.Go to Audio Setting go down to a resetting for the factory audio setting.Tries these steps,tv now should have sound back.
May 10, 2011 | Pioneer PDP-507CMX Television
I am using an internal TV card model "Aver tv go
I am using an internal TV card model "Aver tv go 007". recently I have changed the Intel motherboard of my pc with an Asus motherboard. Sound is not available now. It shows "no suund card is available"Please help mr.RegardsMamun this is my problem
Feb 25, 2011 | Avermedia AVerTV GO 007 Plus/FM Plus...
NO SOUND GOOD PICTURE TV IS ONLY 5 MONTHS OLD
Unplug,replug the tv back about an hour later.Go into the tv menu,go to SOUND,go down to reset it to back to factory setting.The sound now should return,not,than ur tv the Tuner board have problems,call for warrenty serviced.
Jun 28, 2010 | Toshiba REGZA 47HL167 TV
Reset All Settings *Back to factory*
Unplugs everythings like all those cables boxes and the tv also,replugs the tv and those cable boxes,like Time Warner,Telecoms companies Veizon,AT&T,Dish Network,Direct tv boxes about an hour later.Let those boxes updates it softwares.Go in ur tv menu.Go to the menu selection PICTURE,go down select reset.That should reset the incomming broast Tuner board in the tv.Go to tv menu AUDIO,go down to reset.That should reset the audio setting.Now all those boxes have it updates softwares,and the tv reset it back to the factory setting.Now go to tv menu,go to SETUP,go down to CH. setup pick CABLE not AIR.Now the tv will go into scan modes to pick all those cable channels incomming broscast that ur pay for.
Jun 02, 2010 | JVC HD-52G786 52" Rear Projection HDTV
How can i program my rc16 direc tv remote control to my philips tv
1.Press menu on your remote and then go to settings and press select on setup.
2.Go to remote and then go to reset remote.
3.Press and hold MUTE and SELECT until the light above the mode on tv switch on the remote flashes twice.
4.Enter the code using the numbers on your tv.
5.you have cleared AV1,AV2 and tv modes.Move the switch back to DIRECTV;press select on done.
Jul 10, 2008 | Directv RC23 Remote Control
Ilo TV, universal remote
Ilo is made by Orion and/or Sansui.
My Ilo dtv2794B was programmed on Direct TV remote as follows:
In Direct TV mode press 'menu' .
Go to parental ,faves setup
Go to system set up
Go to remote
Go to TV
Select brand (Orion)
Follow directions from this point.
Good Luck>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Mar 16, 2007 | iLO 2600 Television
Samsung HP-R5072 50 in. Plasma HDTV Logo
Jerry Greenberg
Jerry Greenberg
