How to refill ink cartridges?
Fill ink by using the fill hole at the top of the ink cartridge.
PDF instructions: https://www.google.com/search?q=mfc-5440cn+ink+cartridges&oq=mfc-5440cn+ink&aqs=chrome.1.69i57j0l5.13602j0j8&sourceid=chrome&espv=210&es_sm=93&ie=UTF-8#es_sm=93&espv=210&q=mfc-5440cn+ink+cartridges+refill+instruction
SOURCE: Brother laser cartridge refills
OK.. I agree that your problem is with the flag gear. However, there is a specific location in which it needs to be situated. The purpose of the flag gear is to trip a reset actuator on the left side of the printer. The correct position of the flag gear needs to be set so the reset actuator is depressed 3/4 of the way AND where the flag gear moves out of the way once this is done. If the flag gear is moved all the way forward, you run a risk of the gear mechanism inside not rotating it out of the way...which could leave you with a 'no cartridge installed' message. When the manufacturer of the toner cartridge made this unit, they decided to put a mark on the side to, evidently, let the assembly team know where to set the flag gear. Great for us :) On the outside plastic piece that you have to remove to get to the flag gear, you will see a diagonal line and a view window. When you rotate the flag gear, you will eventually see a portion of the white gear in that view window. Line up the white gear portion with the bottom of the diagonal line (typically two gear teeth), and you're done. Assemble and run!
SOURCE: MFC does not recognise the new black ink cartridge.
Disconnect power supply and USB lead (leave disconnected for 10 min). Repeat this for each colour that is not working and hey presto the LCD readout will revert to normal and you will be able to print again. Happy Christmas! Hope this works for you (worked for me)
SOURCE: How to check ink level on brother MFC-9440CN?
Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
Hope it helps.
SOURCE: Just replaced ink cartridges on my Brother MFC
Hi there you can refill Brother cartidges, like other printers it will not have it sorry.
This is the only way you can trick it.
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need:
· Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: I have a Brother MFC-885CW printer. A friend
I have a Brother MFC-885CW also and I have changed the colour inks no problem but now I have just changed the black it will not print black.
