Question about Kenmore 73952 Gas Dryer
Remove front panel - no heat and buzzing sound
How to remove the front panel from Kenmore Gas dryer 92042107
    President:
  • 1,136 Answers
Hi, If the lint screen is at the top of the dryer, remove the screws located at the lint screen. Then pry the top by inserting something flat into the gap between the top and the front panel. Now locate the screw inthe upper inside corners and remove them. Now the front will lift up and release from the cabinet.
If the lint screen is inside the door, the lower half front panel will release and let you see under the drum.
I hope this helps. Please let me know if I can assist you further.
Vic
Posted on May 22, 2009
Kenmore gas dryer heats for several minutes ,then goes cold
I'm haveing the same problem with my frididaire gas dryer. I replaced the ignitor and cleaned the inside parts with a vacume and still having similar problems as yours. I think I will replace the temp. sensor that is attached to the flame tube inside the dryer next. To gain access to the inside parts you will need a putty knife to release the top panel. Just slide the putty knife along the top seam in front of the drryer. There are 2 clips that realease the top peice. With the top lifed up you will see 2 phillips head screws attaching the front panel to the dryer. Remove those screws and lift upwards and the front panel will lift right off the unit.carefully place the front panel to the side without damageing any wires attached. Then all your gas assembly parts will be visable in the bottom left cornner of the unit.
hope this helps,
Aug 23, 2009 | Kenmore Dryers
How to remove front panel from kenmore 90 series gas dryer
Gently pry top of dryer in front corner area. Disconnect door switch inside front. Remove 2 sheet metal screws from inside front. Let me know, Thanks, Sea Breeze
Mar 21, 2009 | Kenmore Dryers
Dryer not heating
what is the model #the heater is not in the back of the he4.
Oct 21, 2008 | Kenmore Elite HE4 Electric Dryer
Removing front panel
The first thing to do is to remove the plastic plug on the lower left front corner of the dryer. it is just a small square plastic piece. This way you can see if the ignitor is glowing red. But to answer your question, You remove the 2 screws underneth the lint filter. Then the top will just pop up with a screwdriver. Then there is 2 5/16 screws holding the front on. (this is for the most common kenmore. If this sounds all wrong i will tell how the other model comes upart.
Oct 19, 2008 | Kenmore 73952 Gas Dryer
Noisy dryer Kenmore Elite 70892 (gas-LP)..
OK, Kenmore,.... I don't work on many of them, but,....
Disconnect power. You have to lift the top to gain access to the screws near the top which hold the front panel to the sides. If it has a top lint filter, you will most likely have to remove the screws holding that to the top, then use a putty knife to release the spring clips at the top of the front panel. Sounds like the blower wheel is spinning freely on the motor shaft, requiring replacement of blower wheel.
Sep 06, 2008 | Dryers
Kemore Elite Dryer - no hot air
kenmore gas dryer heats at first, then cools off rest of cycle.
Jul 26, 2008 | Kenmore 74602 Gas Dryer
Kenmore gas dryer series 80 not heating up--dryer revolves but no heat--guessing it's the ignitor--can't access-no lower panel to open tomroske@msn.com
small plug left side bottom remove it this will allow you to see if ignitor is coming on if it is suspect the coils on gas valve or no gas to dryer if no glow possible bad thermal fuse remove back small white object on blower housing ..if no lower panel ..remove 2 screws under filter pop top 2 clips 1 each side about 2-3 inches from end..2 screws 5/16 1 each side upper corners remove lift front off
Jun 27, 2008 | Dryers
Kenmore elite dryer
can you spin the drum by hand? if not,pull front panel off by removing three screws on bottom, remove lint screen, then remove three screws holding inlet housing ( the big brown thing in front) check to make sure not clogged with sock, panty hose ,bra underwire ,etc.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Dryer
Unplug the dryer turn off the gas valve and remove the rear panel the motor is located below the drum
Dec 15, 2007 | Maytag HYG2460AWW Gas Dryer
MY KENMORE MODEL 110.76722694
You have a bad motor. You can remove and verify probably bad bearings and burnt start winding.
May 16, 2007 | Kenmore 74992 Gas Dryer
Kenmore 73952 Gas Dryer Logo
454 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
