Question about Cell Phones
Nokia 5320d light problem - Cell Phones
I forget security code for nokia 5320d-1
hi Sufian,
what you need to do is a hard reset for your phone. to do that you need to follow the following steps-
1) Power on your handset.
2) Then please press and hold * key + 3 key + Call button + Power button.
3) If you see logo Nokia, then release held keys.
4)
After that enter your lock code. (The default lock code is 12345).
5)
Now your phone will reset and restart.
you will lose all your data on the phone.
hope this helps, all the best.
Apr 01, 2016 | Nokia Cell Phones
Nokia 114 display light problem
how 2 jumper 114 nokia lighting
Feb 05, 2013 | Cell Phones
Master code nokia 5320d-1
try reset codes from online site, there are many which gives u for free
May 10, 2011 | Nokia Cell Phones
Nokia 5320d-1 some keys not working pls help
Just Follow these steps
- Remove the cover(housing) and check keys by pressing the cells - If the problem is same as earlier, remove the mylar pad layer and clean it fully (Including malfunctioned keys) - get small flat screwdriver and short the keypad sensing points - and check whether that malfunctioned keys are working. - if working Clean the miler pad. - if not you need to change the keypad esd filter (Keypad IC)
Mar 11, 2011 | Nokia Cell Phones
Having problem in openig clock folder in nokia 5320d show as system arror
hi
there must be application error in your phone.. restart your phone and access your date and clock . if still having same problem then reinstall the OS of your phone. this will fix your problem. re install your phone and use it
thank you
Dec 26, 2010 | Nokia 5320 XpressMusic Cellular Phone
HOW TO REPAIR NOKIA 1600 BACK LIGHT PROBLEM
Nokia 1600 light problem solution ways. this image is how to repair light problem in nokia 1600. check the link from positive point of battery terminal to the resistor shown as in diagram make jumper as shown and it will work if the link was broken
Apr 21, 2010 | Nokia 1600 Cellular Phone
Nokia 1600 light ic problem
Aug 30, 2009 | Nokia Cell Phones
My nokia 6085 mini display wont light . You can see the time displayed but it is dark.
change the display IC near the main board strip connector, there r two ICs the one on the right side is for mini display , re heat it if it doesn't work after changing the IC ;)
Jun 06, 2009 | Nokia 6085 Cellular Phone
NOKIA 2760 DISPLAY LIGHT PROBLEM
nokia 2760 dispaly light problam
Jan 17, 2009 | Nokia 2760 Cellular Phone
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
