Question about Mitsubishi WS-65869 65" Rear Projection Television
Picture curved in
I have a mitsubishi hd1080 65" tv. the picture is curved in. this problem came about just all of the sudden. i have read that it could be call dry capacitor? what exactly does this mean and what is the procedure for fixing it? thank you for your time. my email is jpsent01@gmail.com
  • Mitsubishi Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on May 22, 2009
Occasionally the picture snaps into what looks like a pincushion.
it is infact pincushioning.. these tv's have a maze of boards.. try to contact manufactuer about pincushion pcb also try to auto converge colours if you can.
Dec 14, 2009 | Mitsubishi WS-55807 TV
Mitsubishi vs-70601 picture pincushioned and out of convergence
could just be a convergence issue. there should be an auto-convergence feature in the menu. outside of that, you'll have to manually converge the colors seperately (also a feature in the menu).
Jul 29, 2009 | Mitsubishi VS-70601 70" Rear Projection...
Mitsubishi 1080 hd series 65" Curved picture
The problem is the convergence circuit.
Mitsubishi used two different types of convergence IC's in this series. The first is a pair of STK-392-570, the second is a single STK393-110. The only way to fix the problem is to replace the appropriate IC'S. In some cases the problem may appear to be intermitent or loose solder connections. Save yourself the anguish and replace the IC'S.
Getting the PowerSupply/ Convergence board
out to do this is tricky and I recommend a professional to do it. Hidden screws on the front of the heat-sink make it difficult to take out and you can break the board easily trying to force it.
Jun 17, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Distorted picture,After power loss
Replace both STKs covergence chips 392-56or 570s use same STK numbers.
Dec 12, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
My Mitsubishi WS-65313 65 inch, Convergence Problem???
This is a common problem on projection tvs. There are two convergence chips that need to be changed. STK394-250 or original Mitsubishi # 267P173010 (recommended)
Mar 05, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Blue, red and green ghosting, curves in picture
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 30, 2007 | Mitsubishi VS-45609 TV
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
296 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
