Question about Polaroid Televison & Video
When i hook up my polaroid tablet to my tv using the hdmi ports and cable it does not show the tablet on the tv
Ive tried diferen t cables my tv is lg
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
Posted on Jan 04, 2008
SOURCE: No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Posted on Aug 27, 2008
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
  • 4234 Answers
SOURCE: my sharp tv is pc ready. I hook everything up and
There are a number of things to check here:
1) Verify that the resolution on the PC is set to a supported level for the TV. Usually the TV will show "no signal" if the resolution is out of range or the message "out of range" will appear.
2) You don't indicate whether you are connecting to a desktop or laptop. If a laptop, you may need to turn on the external monitor. This is done by using the function key and either F5 or F6 (the key should have a picture of a screen on it). Hitting this combination will toggle between the main screen with.without the external monitor.
3) Verify that the TV port is selected correctly (AV1,AV2 etc)
4) You will need a separate cable or the audio regardless of the system type. Also verify that the audio cable is in the corresponding audio input jacks for the video option selected.
If you have completed the above and it still doesn't work, please post the details about the computer being used and the exact cable setup that you have and I'll check into this further.
Thanks,
Dan
Posted on Mar 13, 2010
I want to hook my tablet to my tv, how can I do this?
Use an HDMI cable between your tablet and your TV. On my tablet, the HDMI port is near the micro USB power port.
Jun 03, 2017 | Tablets & eReaders
What cable do I need to hook up to TV to my RCA tablet
Depends on whether your tablet has USB to HDMI ability. You can also buy a converter however they require USB 3.0 and your tablet must have that capability.
Mar 20, 2016 | Samsung Tablets & eReaders
Why is my tv jvc hd70zr7j showing a blank black screen when i connect the hdmi signal cable? the ps3 used to work fine before but since i moved into a new place it just shows the black screen
you have a HDMI port Failure that's not uncommon many people fail to turn the units off before switching cables around it only takes a momentary short on the 5 volt line to one of the other lines and it can short it . or it may just be a normal failure . but you would have to change the .with the AV and HDMI ports on it to restore operation . your set probably has more then one port ? have you tried the others . by process of elimination you have ruled out its the game and cables so it points back to the tv
Jan 07, 2015 | JVC HD-70ZR7J OEM TV Lamp
How do i play movies from a tablet i plugged a hdmi cord but no response
You mentioned a "usb cable" but you cannot connect an external display to a tablet's USB ports. If you are using an HDMI cable, then you will need to select which display is active through the tablet's settings (Android) or control panel (Windows) and also make sure that the TV is set to the appropriate HDMI connection through the input selection.
Dec 31, 2014 | Toshiba 19SL410U 19 LCD TV
Poloroid 42" lcd - high pitched sound from the
That HDMI port is shorted and dying.Just don't used that HDMI port.That the cheapest and easy way,just by pass that HDMI port.Other wise than u have to spend like $130 -150 to buy a whole refurbish tv Tuner signal board for the replacement.Because those HDMI ports,dosen't have any indiviual sell by itself as HDMI port as part.
Nov 15, 2010 | Polaroid TDX-03211C LCD TV
BEST CONNECTION FOR TAPE PLAY ON HDTV. VCR HAS BOTH HDMI AND S-VIDEO PORTS PLUS THE STANDARD A/V PORTS
Use the HDMI cable to hook up the DVD/VCR combo.Use the HDMI ports and cables,best result for the new format HD Movies,Tv's shows.Less clotters too.
Mar 20, 2010 | Televison & Video
I have my polaroid hooked up with an hdmi cable
Thats because your TV is not high definition and cannot process the high def signal. serial hook up does not give a highh def signal.
Nov 09, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
