Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon Pixma 210 series has an error code 6000, won't print or scan
The device doesn't print or scan. an error code 6000 appears, what's the problem?
  • 1 more comment
  • Anonymous Mar 15, 2014
    Error code 6000. Printer will not print
  • Anonymous Mar 19, 2014
    cannot print error 6000 appear what can i do
  • Anonymous Mar 24, 2014
    pixma mp210 scanning problem shows code error 21140
    Champion:
  • 214 Answers
Hope this helps
With thanks to a canon tech
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Posted on May 22, 2009
HP PRINTER LASER JET 600 ERROR 59.00.90
HP is one of the most reputed tech brands known for its range of unique and high-end printers. Although the printers and scanners are manufactured with the highest quality parts and technology, the devices are still prone to errors and defects. Some of the common issues faced by people while printing and scanning are printing error, connection errors, invalid print commands, cartridge issues etc. So why you waste your time call now: 877-690-9305
Support For Hp Printer Call Toll Free 877 690 9305
Jun 17, 2014 | HEWLETT PACKARD - LASER JETS HP LaserJet...
Error code 6000
Go To Below official Canon Printer Page For Your problem http://forums.usa.canon.com/t5/errors/FilterErrorHandlerPage Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us ForCanon Printer Support
Mar 12, 2014 | Canon Pixma MX360 Printer
My canon image runner 2520 has been duly bought and well powered, but it brings error code e000020 and it does not print or scan,i need immediate help.
the problem is when i have replaced the drum of my canon ir 2520,appeared for me two big black lines and then appeared that code :e000196.thankssssssss.
Jul 20, 2011 | Office Equipment & Supplies
Mp250 error # 6000
put a whole lot but really lot of pages in the place to put them,that will push the cart downwards..and then it will work properly :D
May 15, 2010 | Canon Office Equipment & Supplies
Action to be taken with error 6000 on MP470
This Error (error 6000) occurred while attempting to print something. Follow this instruction to clear it.
1) Reset your device:-
  • On the operator panel, press and hold the ON/OFF button for one second. (The display will go blank.) If pressing ON/OFF button does not shutoff the device then unplug the power cord.
  • Wait Approx. 10 Sec then press power button ON/OFF button again.
  • Wait until the device has completed its cycling process before submitting another job request.
2) Remove Paper Jam if any
Else your device need service (repair)
Good luck...don't forget to rate the solution
Feb 22, 2010 | Canon PIXMA MP470 All-in-One Printer
UNABLE TO PRINT DOES NOT RESPOND TO TROUBLE SHOOTING PROVIDED IN USERS GUIDE THIS IS ONLY USED TO COPY AND SCAN & COPY
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 24, 2009 | Brother MFC-5840CN All-In-One InkJet...
Error code 6000
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Apr 27, 2009 | Office Equipment & Supplies
Error code 6000 on canon pixma mp210 stops me from printing
Error 6000 means - The specified file could not be encrypted.
Solution: reinstall the printer driver.... it's better to install a upgraded version of driver...
Good Luck!!!
Mar 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error 6000 is shown!!!!!!!
whenever it try to copy scan or print by canon pixmamp150 printer it shows error 5?please give me a solution to solve this problem.pleeeeeeeeeez
ayman refaie
ayman_refaie@yahoo.com
Feb 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon bjc - 6000 6 orange flashes
Please help me Service error 6A00 Cancel printing and turn the printer off and then back on.
If this doesn’t clear the error, see the printer manual for more detail.
Apr 24, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
984 people viewed this question
old marine
old marine
