Question about GE WSXH208A Front Load Washer
Kenmore model417.41142000 washer shakes vigorously on spin cycle only with clothes in it without clothes machine runs fine
I just went through kinda the same problem and when I took it completely apart I found the spindle hub was broken on 2 of the 3 supporting arms. they where just eaten up bad/corroded. I had to buy the tub/spin assembly which is the techincal name if you happen to need this part.once you pull tub house out of washer you need to split the tub and then you can see if this is the same problem I had
Posted on Nov 02, 2007
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
Spin cycle problem
I had the same problem you need to pull out your washer and observe which leg is uneven this should be the source of your shaking and if you use the proper tools you can solve this.
Dec 31, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
While replacing motor coupling and vigorously moving motor gearbox around, something dropping on the base of drum but could not see what it was. And after completing the motor coupling job , I set the...
those pins are not important they are there for transportation purposes such as moving from one home to another or country don't worry about them. As far as the shaking and walking use a level and level your machine in both directions.
Mar 25, 2009 | Kenmore 24032\24036 Top Load Washer
Washer shakes real bad in spin cycle
Does it do this when the drum is empty?If not, then you may be overloading the unit with clothes. Or, the clothes may have entangled into a ball. Untangle and spread out.
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Kenmore 80 series washer wont rinse/spin
I fixed the same problem by using this site: http://forum.doityourself.com/archive/index.php/t-156215.html
Mar 17, 2008 | Washing Machines
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore Washer won't agitate, spin or drain
It's not your exact model but does have some good information about the possible causes.
http://www.shopyourway.com/questions/1099421
If you need further help, reach me via phone at https://www.6ya.com/expert/sean_97e45db9c0ed1da4
Apr 07, 2017 | Washing Machines
Washer shakes vigorously
The front 2 legs should be screwed in completely, and locked with the check nut. This means the machine is lowest in the front. If you find any shake (try with both your hands) adjust accordingly. Normally the machine adjusts itself if the weight is un-balanced; but it cannot do anything if the legs are uneven.
For Flinsky:
There could be some spring or shock-absorber come loose inside the machine. Plug off the wall, remove panel behind & check. If you could remove the top to check fine.
Oct 19, 2007 | GE WSXH208A Front Load Washer
Kenmore 23832 top load washer
lalocke If the load is not properly balnced, your washer will shake too much on the spin cycle and it wlll never go on full speed. Gendos...post back
Mar 01, 2007 | Kenmore 23822 Top Load Washer
GE WSXH208A Front Load Washer Logo
80 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
