Pm 746 bontempi - Computers & Internet
Cant disable simlock code on a samsung e250.
Hi Use the following code
#7465625*746*Code# ( Disables SIM lock)*7465625*746*Code# ( Enables SIM lock)
Use this code on your phone to disable/enable SIM Lock on E250
Jun 21, 2011 | Computers & Internet
I am using a 160,000 btu unit, and would like to figure out the electrical cost (not factoring kerosne costs) to run as I am using someone else's power. What I am looking for is the wattage used at max...
kilowatts= electric motor rating in horse power X 746 watts X 24 hours X 60 minutes X 60 seconds/1000
1.50 hp X 746/1hp X 24 hours x 3600seconds =
1.5 * 746 * 24*3600 =96681.6 kilowatts/day
Nov 25, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Broken volume pedal on bontempi 24110008 organ.pedal wont stay in up position.
There MAY be a counterbalance spring that is missing or broken AND there HAS to be a friction device to hold the position. You should be able to remove the pedal assembly to analyze and repair it.
It may involve just tightening whatever is suppose to create the friction to hold the pedal.
Apr 24, 2010 | Music
Xerox workcentre pro 5225 exrror code 026-714
the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
Feb 26, 2010 | Xerox Workcentre 5225 / Copier, With...
How to play minor chords on Bontempi MS40?
easy:
- the lowest key gives the chord C for C major (do majeur)
- add a key on the right (up) for exemample D or E or (it doesn't a matter) gives you the minor chord.. (here Cm = do mineur)
- add a third one ( always on the right side) gives you the 7 here C7 (do septieme)
enjoy!
what a pity we can't easily disable this auto chord function in orfer to get real notes for the left hand!!!
Jan 22, 2010 | Bontempi Toys
I forgot my sim pin for sgh-e250 help neone?
Hello! SIM enable= *7465625*746*
SIM disable= #7465625*746*
Guru..............saailer
Jan 07, 2010 | O2 Samsung SGH-E250 Cellular Phone
Open Questions:
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
