Question about Dishwashers
Defy dishmaid my dishmaid super silent goes through the complete cycle, but does not wash the dishes, leaving a residue of dirt in the inside of the machine
  • 30 Answers
SOURCE: Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
Posted on Jan 05, 2007
SOURCE: Dishwasher residue
there is a new product out called the Difi dishwasher filtration system. it filters the water going into your dishwasher and will solve the problem. after i hooked it up(which takes no time at all) i could not believe how clean my dishes came out. it is very affordable and fits under the sink. you can check it out at www.dishwasherfilter.com
Posted on May 02, 2008
SOURCE: Defy Dishmaid Dishwasher (12 place), 2 years, 3 months old
Well, I fixed it in my case, by opening it up and taking a look. It seems that water was leaking out of the main compartment into the guts of the machine and shorting out a solenoid (I think). In my case, the water was leaking at the location where the 'water hardness adjustment' knob/screw is. This is in the middle of the left inside wall. (Take a look at your manual)
This may or may not be the problem in your cases, but it certainly produced the same symptoms. You need to be somewhat technically inclined to do this, and ABOVE ALL, make sure the dishwasher is off, unplugged and the water supply is turned off before going any further...
You start by taking off the top 'preparation surface' o the dishwasher by lifting two plastic clips at the back of the machine and sliding the top backwards and off. Next, by removing the left cover plate of the dishwasher (there are screws at the back, top and front of the machine), you expose a large flatish plastic device about 150x300x15mm that is responsible for dividing up the incoming water to add salt to one portion and then presumably recombine the water. This is held in place by two clips on the left side and the large ring around the water hardness adjustment screw on the inside of the machine. Twist off the ring and give the plastic thing a good pull to loosen it from the black tar-like stuff. Once it is free, you'll see a black o-ring that seals the joint between the plastic device and the main compartment. In my case, this was full of gunk and not sealing properly. I gave it a good clean and refitted the whole assembly. For good measure I also checked the clips securing the hoses connecting to the plastic device and made sure they were sound.
There is an electrical connection to what I think is a solenoid below the plastic device described above at the bottom of the machine. In my case, water was dripping down on top of the electrics when the machine took in water and I guess must have shorted out the solenoid, bringing the whole water delivery process to a halt. This created the mpression that the machine would fill up with water and go no further. I gave the whole area a good dry with a cloth. I also had to tilt the whole machine and allow the water that had, over the last few days acumulated inside, to drain out.
When everything was dry, I put back the cover plate, plugged the machine in and turned the water on and tested with a rinse, then a number 3 wash another three times. Everything worked fine.
Please be very careful when working with machines like this. Electricity and water don't really mix. I advise if you are not qualified that you ask a suitably qualified person to do the job for you.
Good luck.
Posted on Jan 18, 2009
duotom7
  • 6 Answers
SOURCE: dishwasher leaving a white film on dishes after wash/dry cycle
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
Posted on Mar 18, 2010
  • 677 Answers
SOURCE: White residue left on dishes; Plastic ware being oxidized
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Posted on Nov 15, 2011
My dishwasher is left quite wet inside after washing dishes. Is this unusual, especially for an expensive Viking dishwasher that is brand new?
make sure you have selected the heated dry option. for the smell, add a 1/2 cup of white vinegar to wash cycle.
Jun 21, 2015 | Viking Dishwashers
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
I am using the same quality products to wash the dishes as I have done in the past when I used this machine effectively but now--it doesn't seem to clean the dishes and leaves a film and food residue. My...
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
See part 1 on this parts list and diagram. http://www.partselect.com/MultiModels.aspx?ModelNum=kuds03ft&searchTerm=img_6G53WSWK&RefineSearch=0&imgMfg=Whirlpool
May 17, 2010 | KitchenAid Architect? II S SERIES KUDS03FT...
Whirlpool Built-in dishwasher Model DU8700XB -O
Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
It's under the lower spray arm. Post your model number and I may can find a diagram for you. Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Mar 22, 2010 | Dishwashers
Residue is left behind after cycle is complete. Dishes looks dirt
if dirt is not being washed away it is most likely you have a clogged screen before the waste tube. Depending on the model. Dismantling the dishwasher takes place inside it and under it where the motor is located.
Mar 13, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
My dishwasher leaves a cloudy residue on my dishes
The cloudy residue that is left on your dishes is soap that has not completly broken down.
There are a few solutions to the problem. First off, you want to ensure that you are using the "high temp wash" option. This will boost your water temp during the wash cycle to ensure that all the soap breaks down.
The second thing that you want to do to give your dishwasher a boost, is run the hot water in the sink and make sure it's pipping hot before you start your dishwasher. What this will do is ensure that the water that goes in for the "pre wash" portion of the wash is hot and will improve the wash quality.
Mar 01, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Leaving white residue on dishes salt ok any ideas please
A white residue could be some type of water hardness or residual detergent. Wash dishes by hand and dry, does white residue remain? If yes, there is too much detergent in machine. If no, water problem. Consult with a local water expert
Aug 19, 2008 | GE Adora GHDA656LSS Stainless Steel...
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
