Question about Samsung CLP-770ND Laser Printer
Transfer belt reset - Samsung CLP-770ND Laser Printer
C13c8
C13C8 A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
When a new transfer belt unit is installed in a machine an internal component on the transfer belt unit changes state; this now indicates that the transfer belt unit is used
http://kmcopierservice.blogspot.com/2011/02/how-to-reset-transfer-belt-bizhub-c203.html
Apr 10, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Samsung clx-2160 printer is showing transfer belt error. how do i sort this
transfer belt (and other consumables) will reset follow this procedure:
1. go in diagnose mode:
menu - # - 1934 - menu
2. in tech mode -consumables counter - transfer belt -reset
3. after 20 sec. power off and power on
When transfer belt count 60.000 image need to reset.
good lock!
May 28, 2011 | Samsung CLX-2160N All-In-One Printer
Have a transfer belt error What to do?
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Apr 02, 2011 | Samsung CLX 3160fn All-In-One Printer
How to fix transfer belt error in my samsung CLX3160fn
3. Select Tech Menu
4. Select DataSetup
Feb 27, 2011 | Samsung CLX 3160fn All-In-One Printer
My window is showing "replace transfer belt soon" what is that and where is it and where do you find a transfer belt?
Transfer belt (and other consumables) reset follow this procedure:
1. go in tech mode:
Press consistently menu -> # -> 1934 -> menu
2. in tech mode find ->consumables counter -> transfer belt ->reset
If this not help try this:
1.MENU # 1934 MENU
2.Tech Mode (not User Mode)
3.DataSetup
4.Clear All Memory
Oct 27, 2009 | Samsung CLX 3160fn All-In-One Printer
Lexmark C522n Laser Printer stating "83 replace transfer belt"
how do you reset the transfer belt of a Lexmark C522 colourlaserjet.
Thanks
Alex
Mar 18, 2009 | Lexmark C522n Laser Printer
Need to reset counter for transfer belt
to reset the counter on the toners and transfer belt see:
http://www.dunfield.com/clp510/
Oct 28, 2008 | Samsung CLP-510 Laser Printer
Transfer roller
Use the keys on the control panel to select the following menus: setup|maintenance|check others|transfer belt|reset then press [enter]. The LCD should read "reset now" and the printer will return to the ready prompt.
This assumes the error message you have is for the transfer belt near end and not the transfer roller itself (which is NOT part of the transfer belt, it's actually attached to the RH door as you look at the control panel).
Oct 16, 2008 | Samsung CLP-500 Laser Printer
Reset transfer belt samsung clp-300
Unfortunately you cannot there is a resistor on the unit that when you replace it it blows resetting the transfer counter.
Sorry
J
Jan 08, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP-770ND Laser Printer Logo
67 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
