Question about ASUS Eee PC 1000H Laptop
My screen won´t turn on
My Asus EEE PC 1000H screen will not turn on, the computer sounds like it is starting but I cannot get the monitor to turn on. Any suggestions??
  • 1 more comment
  • timmc84 May 22, 2009
    No I coudn´t see any dark messages and when I tried too plug in an exterior monitor it also was blank.
    Thanks
    Is there any way that I can remove data before doing any of this? We have photos on their that we don´t want t lose, possible using wireless or bluetooth?
  • Frank Zhang
    Frank Zhang May 11, 2010
    could you see dark messages show on screen when it works?
    and could you connect to a Ext VGA monitor is there normal show?
  • 191 Answers
You need do check:
1) find your laptop RAM memory stick location reference:
http://myeeeguides.wordpress.com/2008/10/15/eee-pc-1000h-ram-upgrade/
2) take out the RAM clean pins then reseat it back, turn on, if still dark screen your laptop got trouble at onboard memory, need send to repair.
hope hep you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
Posted on May 22, 2009
  • 2 more comments
  • Frank Zhang
    Frank Zhang May 22, 2009
    add to step 2) if still dark screen, you need change this RAM then test. nothing fixed, your onboard memory chips failed.
  • Frank Zhang
    you can backup your document before check and fix. you need take out HDD under keyboard, then check memory and do fix the dark screen which does not need HDD, untill fixed then reseat back HDD.
  • Frank Zhang
    please take a rating if the solution helped you thanks! keep in touch your comment.
  • Frank Zhang
    Frank Zhang May 24, 2009
How to increase brightness without fn+f6 keys because for now the f6 key is not working
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Oct 08, 2012 | ASUS EeePC1000 1000H 1000HA 1000HC 1000HD...
Connect 2 external monitors to ASUS Eee PC 1000H
You might be able to use a usb video adapter to do this.Sabrent USB-DH88 PC-to-TV Multi-Display Video Adapter - USB 2.0 to DVI/VGA/HDMI, 1400 x 1050
Apr 25, 2012 | ASUS Eee PC 1000H Netbook
Windows wont start up when computer is turned on, at the bottom of the screen, it just says press f for set up or tab for bios memo, then the screen will be blank with just a cursor blinking
If you are interested in solving the problem more easily and quickly. I think you can try this computer boot up suite, a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all.
Jun 25, 2011 | ASUS Eee PC 1000H Laptop
I am unable to connect my Eee PC 1000H to an
You'll need to us the Fn key functions.
Check out your keyboard, there should be a Fn key, probably on the bottom row. Also, probably in the number row, there's a set of dual function keys, one will have a picture of a screen.
Press the Fn key and the screen function key at the same time, should switch between external and internal screen.
Jul 21, 2010 | ASUS Eee PC 1000H Laptop
Bluetooth doesnt work- says no device. FN keys doesnt work on the screen, only turns on and off wireless.
You have to reinstall the ASUS Eee bluetooth driver. If you've your CD driver, insert it in and look for Bluetooth. Otherwise click on this Link to download it;
http://www.notebook-driver.com/asus/asus-eee-pc-1000h-netbook-windows-xp-driver-and-utilities/
Good Luck!
Jun 24, 2010 | ASUS Eee PC 1000H Netbook
When I turned it on, it goes to the screen that has start windows
sounds like your boot record on hard drive is bad or hard drive turn on computer and hit like f10 or f12 it will tell you right after asus screen what key to hit for restore, if this doesn,t work hard drive is bad. hope this was helpful
Apr 15, 2010 | ASUS Eee PC 1000H Laptop
Eee Pc starts with blank screen. it starts up and goes straight to a blank screen. wireless and power light on. No hard drive light. what can be done to this?
it could be a ram issue. if you're proficient with your hardware and the lappie is out of warranty try removing the ram sticks then re-seating them. this resets the ram and allows the monitor to turn on
Feb 25, 2010 | ASUS Eee PC 1000H Laptop
CANT GET WEBCAM TO START
Try turning it on in the utility icon (located in the lower right portion of your screen).
Apr 28, 2009 | ASUS Eee PC 1000H Laptop
MY WEBCAM WON T WURK AND I CANT FIND THE DRIVER PLZZ PLZZ HELP ME
try turning the webcam on from the utility tray icon (located in the lower right portion of your screen).
Apr 22, 2009 | ASUS Eee PC 1000H Laptop
ASUS Eee PC 1000H Laptop Logo
1,547 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
