Question about Samsung CLP-770ND Laser Printer
Reset fuser - Samsung CLP-770ND Laser Printer
Ho do I reset my MFC8480DN after replacing the fuser unit?
This is the fuser reset procedure from page 563 of the service manual:
5.1 Resetting the Periodical Maintenance Parts Life
? Resetting the Life Counter of the Fuser Unit
<Function>
This function allows you to reset the page counter of the fuser unit and increase the number
of replacement times by one.
<Operating Procedure>
(1) Press the [3] and [9] keys at the same time in the ready state.
The "Reset Menu" will appear on the LCD.
(2) Press the [ ] button a few times to select "Fuser".
(3) Press the [OK] button.
The "1. Reset / 2. Exit" will appear on the LCD.
(4) Press the [1] key when resetting the life counter of the fuser unit. Press the [2] key if not
resetting.
(5) The "Accepted" will appear on the LCD if pressing the [1] key. The page counter of the
fuser unit is reset, and the number of replacement times is increased by one. Then, the
machine returns to the ready state. If pressing the [2] key, the machine do not reset the
page counter and the "Fuser" will appear on the LCD.
Feb 10, 2015 | Office Equipment & Supplies
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
Hp cm4540 fuser kit counter reset
allot of the newer HP printers can not be reset they have a fuse in the new fuser when it is installed it blows the fuse in the new fuser & resets the count.
Aug 01, 2012 | HEWLETT-PACKARD CM4540 AllInOne Laser...
Hp 4730 fuser reset
Anyone with information on how to reset the Fuser page count without chanigng the fuser on HP 4730 MFP? The fuser in the unit is in very good condition and replacements are not cheap. Any help would be much appreciated.
Mar 12, 2012 | HP LaserJet 4730 MFP Printer
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
I have just fitted a new image fuser kit to our HP 4650 laser printer. However, the error message "replace fuser kit" reappeared on switching the printer back on. Any ideas. Have taken it out...
To reset the fuser count, do the following:
1 Press to enter the MENUS.
2 Press to highlight CONFIGURE DEVICE.
3 Press to select CONFIGURE DEVICE.
4 Press to highlight RESETS.
5 Press to select RESETS.
6 Press to highlight RESET SUPPLIES.
7 Press to select RESET SUPPLIES.
8 Press to highlight NEW FUSER KIT.
9 Press to select NEW FUSER KIT.
10 Press to highlight YES.
11 Press to reset the fuser count.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | HP Computers & Internet
Hp 4650 n - New Fuser Kit
Under the menu>Configure Device>Resets>Reset Supplies>New Fuser Kit
Oct 28, 2008 | HP LaserJet 4650n Printer
Reset page count
Hi bseema:
Hope that this helps you.
Resetting Fuser Life
This procedure restarts the counter that tracks Fuser life. Perform this procedure after
you install a new Maintenance Kit.
To reset the fuser:
1. From the Main Menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life
Oct 13, 2008 | Xerox Phaser 4500 Printer
Resetting lbp fuser
you need to do a lbp fuser reset and lbp error log clear
fuser reset
function- 7- monitor button 4 times slowly- then press * "start" button, should say service mode, then press 7- start- down arrow - start- then yes
log clear
function- 7- monitor button 4 times slowly- then press * "start" button, should say service mode, the press 6 - use the down arrow to get to lbp log clear.
if this does no work you need the fuser replaced
good luck
Oct 12, 2008 | Panasonic PanaFax UF-490 All-In-One Laser...
Samsung CLP-770ND Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
