Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Switch diagram needed
When i removed my swtich from my black and decker mm875, I neglected to note which wire went where. i'm looking for that information
thanks!
Funny, I came here because I just opened up the switch case on my MM875. Hold the switch so the terminals are on top. Call the black switch (the part you push in to power up the mower) north. The north post gets white (metal connector). The west post gets red (plastic connector). The east post gets the black that comes from the mower's motor (plastic connector). The south post gets the black that comes from the outlet (metal connector)
(Black Plastic Switch)
White (Metal)
Red (Plastic) Black (Plastic--from motor))
Black (Metal--from outlet)
Posted on May 22, 2009
Black & Decker Lawn Hog 19" Mulcing Mower MM875 won't start
The rectifier is a flat plate with 4 posts that attach the electric wiring inside. You will need a flathead screwdriver to remove the four screws holding down the cover on your mower. on top where all the wires run (you will probably see one burned) There is a screw in the middle holding down the plate, you will need to replace the plate and resplice the wires that may be burned.
May 31, 2009 | Black & Decker 19" Electric Lawnhog...
Where can I find a Manual for Black Decker 19\'' Mower
Is this the lawnhog model MM875?
http://www.blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=2508
Check here for the owners manual
Apr 18, 2009 | Black & Decker 19" Electric Lawnhog...
Black & Decker MM875 blade
You can pick up a blade at almost any hardware store.
Sep 26, 2008 | Black & Decker 19" Electric Lawnhog...
Black and decker mm875 mulching mower stopped working after 4 uses
check handle terminal if not burnt/melted,switch terminal ,
terminal on the rectifier & thae armature commutator.inspect & report.
Jul 10, 2008 | Black & Decker 19" Electric Lawnhog...
Mower tripped outlet breaker - wiring schematic available?
I had a MM875 go out after some months' service -- it actually went out with a bit of a bang. The problem was a shorted circuit; the weather was hot and the "solid state switch" on top of the motor shorted out. This part wasn't a switch but a bridge rectifier. The original part was specified a bit close to its actual working limits so I bought another (from Radio Shack, no less) that was higher rating -- something like 30 amps at 200 or 400 volts. ITs worked for years.
If it is a bridge then it will have two terminals labelled '~' and one each with the '+' and '-'. The plus and minus go to the motor (keep those connections the same as the original) and the others go to the supply wires.
Jun 16, 2008 | Black & Decker 19" Electric Lawnhog...
I have a black & decker lawnhog mm875 lawn mower that just stopped working. the power to the mower is good. can you help
I had the same problem. Its the switch.
When you pull the plastic handle up, it pushes down a button switch located in the handle. Over time (and with use) the parts begin to wear and the handle is no longer aligned properly with the button. So, ........ when you pull the handke up the button is not pushed in far enough to start the mower.
I want to bypass the handle and hard wire the mower but I can't find a wiring diagram.
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
687 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
