Question about Maytag Performa PAV2200
Whirring noise in spin cycle, 7 year old machine
Just started, whirring sound starts when spin cycle is initiated. Open lid and spin stops with noise stopping., sound not unlike a pulley spinning but not hi pitched.
  • Anonymous Nov 06, 2007
    It looks like my pump is making that same deep whirring sound in the spin cycle I think the bearing must be going. It also seems to be leaking past the seal.
  • khanti Nov 06, 2007
    yes
    Scholar:
  • 196 Answers
Checking the pump woulb be the first step. The pump bearing get worn and begin to sqeal. If the pump is alright then the problem could be the spin bearing.
Posted on Jan 13, 2008
Machine stopped and bells rang
It sounds like the water pump has seized judging from the noise that you were hearing.
When the water seals become old and worn, water seeps through and ends up in the pump motor bearings, which corrode and eventually fail.
Open the machine up and check the pump, they are not repairable, will have to be replaced should this be the case.
Feb 08, 2016 | LG Dishwashers
Maytag top load washing machine 2 years old
This could be partly the clutch/break assy. You need to be able to run this with the lid open in the spin position. Activte the lid switch with a pencil or something. Reach in and hold the spin basket and then turn the washer on in spin. Hold this basket for 1-2 minutes then release it and let it reach full speed then stop the washer by turning the timer off or releasing the lid switch. See if the hard breaking/noise is better. Keep doing this untill it comes to a smooth stop and the noise is gone at the stop. Not sure this will cure the noise in the spin starting up problem or not, but start here. the clutch gets rust on the pads and this burnishes the break pads, removing this rust that makes it grab.
Goodluck..
Apr 05, 2008 | Washing Machines
INDESIT WIB101 WONT SPIN
Have you checked the lid safety switch? Even if it doesn't spin, the cycle timer will continue.
Nov 16, 2013 | Washing Machines
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Ge washer whdsr209d wont engage spin cycle
It is probably the lid switch. you need to look for it, it will be somewhere where the lid meets the top of the machine. When you find it, bypass it. You will just have to be careful after doing this and remember that when you open the lid, it will not stop spinning or what ever cycle it is doing at the time.
Oct 15, 2017 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Washing machine won't spin until open and reclosed the lid
sounds like transmission not resetting for spin properly replace transmission
Nov 20, 2008 | Estate ETW4100SQ Top Load Washer
Spin Cycle Noise Stops when Lid is Opened and Does Not Come Back
The first thing to do is to make sure there is nothing sticking through the holes in the basket that is rubbing the inside of the tub.(nails, screws, wires)
If this is ok, tilt the machine back so you can remove the belt and turn each pulley individually. Be sure to turn the transmission pulley both directions.(it is the big one) The most likely culprit is the water pump has something in it or the seal sleeve on the pump has fallen out of place and is rubbing the pulley.
Post back with what you find out and we will go further if we need to.
Oct 31, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
280 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
