Question about LG Televison & Video
Cannot re scan our tv - LG Televison & Video
    Top Expert:
  • LG Master
  • 74,136 Answers
Make a hard reset to this TV and check. Just unplug it from AC mains wall socket, and re-plug it back after 20 minutes or so. This must make it a hard reset. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Posted on Jan 03, 2014
Set stations
A channel scan is a vital part of utilizing your cable TV service. When a coaxial cable is connected to a TV, sometimes it will not display any channels until you configure the TV for your specific cable connection and scan for available channels. A channel scan can be applied to basically any type of TV or TV/VCR combo, even if you are missing its remote control.
Read more : http://www.ehow.com/how_6875646_do-old-tv_vcr-tv-remote_.html
Instructions
    • 1 Bring up the TV's menu. Look for a button on the front panel of your TV/VCR labeled "menu" or "setup." Press it and you should see a menu appear on the screen. Part of the menu should inform you what buttons you can use to navigate through the menu. If not, try using the volume buttons or channel buttons on the front of the TV and see if pressing those allows you to navigate through the menu.
    • 2 Specify channel scan settings. Once you are able to navigate through the TV's menu, look for the "channel scan" "auto-program," or "auto-tune" option. This may be inside one of the TV's sub-menus such as "setup," "channel setup," or the like. The key of this step is to specify your cable settings before running your channel scan. The "tuner mode" option needs to be set to "cable" rather than "air" or "antenna." You may have to specify what cable type to use, this will be set to "std" or "standard" for the vast majority of cable providers. If you are not certain what cable type you use at home, contact the technical support department of your cable provider.
    • 3 Run a channel scan. Once the scan settings have been set properly, run the scan (usually done by pressing a "start," "scan" or "begin" button.) When the scan is complete, check to see if you are getting all of your channels. Contact your cable provider if you are not sure how many channels you are supposed to be getting.
good luck
Jan 08, 2015 | Televison & Video
JVC TV LT-42X579 LCD TV 42 in.Does this TV have a Lithium battery for maintaining memory, similar to PC computers?
No. It has no such battery inside. Its memory IC is non-volatile type, and need no back-up electric charge to retain the data, even after it is switched OFF. http://electronicshelponline.blogspot.com/
Sep 18, 2014 | JVC LT-42X579 42 in. LCD TV
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
How to make TV scan cable channels
the tv scan function is for antenna users. If youre using a cable/dish box, any kind of digital tuner than you do not need to scan for channels. just select your digital tuner
Feb 04, 2012 | Sharp LC-19SK24U TV
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
Sep 25, 2011 | Dynex Televison & Video
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
Need to know scan frequency of the computer
Most TV have interlaced 60, which is really 30 hz...
You can set your computer's scan frequency by right clicking on desktop, then going to the rightmost tab, under advanced, click on the monitor tab and select 60 from dropdown tab...
However, most videocards output Svideo to tv, not VGA so don't worry about it. if your TV has VGA in, you can select 60, but if it has VGA in, it probably has greater than 60 capabilities... but 60 is rock safe for everything.
Apr 19, 2009 | E-Machines eMachines Desktop PC
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
I accidentall setup up my tv for ez scan now what??
when your in the EZSCAN mode and its scanning you can skip the scans that you want by pressing ENTER when it begins on the scans you dont want..It will tell you what is scan mode is DTV,CABLE,ANALOG TV .Press ENTER as soon as it scans the unwanted scan modes then let it scan on DTV ..
Dec 07, 2007 | Zenith TV SPEAKER SYSTEM, FOR 50" PLASMA...
Televison & Video Logo
14 people viewed this question
Computer Repairing
Computer Repairing
