Question about Samsung ML-1640 Monochrome Laser Printer
It dose not check wen tuned on and red light is on dose not print
My 50" insignia wont turn on wen im plug to light turn on the screen and red light but turn of with clik nose
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 08, 2016 | Insignia Televison & Video
Have a 1996 camaro that is idling high and rough
Check your mass air flow sensor on your air intake it has a connector plugged in it or just take it in for a full tune up
Mar 07, 2013 | 1996 Chevrolet Camaro
Got a new lamp tv works great but wen I turn it off it has a very quiet hum is this normal also wen I turn it off blonks green for a while befor eventualy going away what dose this mean...
Hello; The noise when turning set off is likely the fan that cools the lamp down gradually. The lamp can crack if the fan does not work. Dust in the fan can also add to the noise. When the set is turned on, the microcomputer watches the lamp come up to full brightness and shows this with the LED colors. All lamps containing mercury take time to get up to full brightness.This also applies to mercury compact florescent lamps, yard lights, and even neon signs that contain mercury.
Jun 07, 2011 | Toshiba 52HM95 52" HDTV Projection...
Printerapprears to be set up carrect with standard
I would try uninstalling the printer and restart pc and reinstall it.go to web support for your printer and get the newest driver/software package make sure you get the package for the OC you have.Check out the manual for help if this dose not work,the information in the manual is priceless.
Nov 29, 2009 | HP LaserJet 1018 Printer
Mi k8001 battery has been dieing really qwickly wen iv had it on charge for hours and know it dose not turn on att all and the red light just keeps flashing when i try switching it on :S HELP ME ...
the reason why is because when you have charged it you might bot of let the battery go down totaly and kept on charging it when it was just half full so it might think to it self "oh ok i'm always going to be charged half way so it will just go straight down and think that is when the batterie energy is gone down" Good luck!!!
Jul 14, 2009 | Sony Ericsson K800i Cellular Phone
Red light green light yellowlight red blinking light
PS3 has overheated, and caused the solder under the cell processor to get that hot it's melted.
When they've dried / set they have had either cracks appear or they have become warped.
The only solution is to reflow / resolder these joints.
We offer a well priced repair service, and also a longer warranty than most.
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Tv wont turn on
i have a nlc-3204bc funai hd ready, the stand by light keeps flashing red on and on, can not switch it on
Feb 17, 2008 | Televison & Video
Samsung ML-1640 Monochrome Laser Printer Logo
27 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
