2006 Pontiac Montana SV6 Logo
Posted on May 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a pontiac montana, but lately when I press ths remote start button, the alarm goes off. Door locks work fine.
I have a pontiac montana, but lately when I press ths remote start button, the alarm goes off. Door locks work fine.
  • cypress233 May 22, 2009
    It's a stock keyless entry. I just changed the battery in the remote, and the door locks etc are working better. But when I press the start button, the panic alarm still goes off..wondering if it needs to be reset?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Dec 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
4538
Points
7
Dec 2009.
I also have a 2006 sv6 witht he exact same problem. The battery diesd in the remote and after changing it only sets off the alarm now instead of starting? Di dyou figure out the problem?
jakcars
Level 2:
Sergeant:
  • Pontiac Expert 304 Answers
  • Posted on May 22, 2009
jakcars
Pontiac Expert
Level 2:
Sergeant:
Answers
304
Questions
Helped
85380
Points
946
If its an aftermaket installation, do yourself a favor and have it removed. I have seen them disable a vehicle where they won't start. Sound like the controller is malfunctioning.
1helpful
2answers
The alarm turns on when I put the key is in the door lock. Is there alarm reset?
Are you using an aftermarket key or the original? It may have a chip in it. Also if you have a spare original try it.
2008 Pontiac Montana S6 Won't Start.
Sounds like the anti-theft/alarm system was triggered.
Have you tried locking and unlocking the driver door with the key to disable the alarm ?
And you need at least 12 volts to crank the engine so the battery may need to be charged up first.
Keyless remote
hi Alan
what procedure you are doing for remote matching?
try this one and let me know.
1 Unlock the car, get in and close the door
2 Switch ignition on
3 Press the door lock button on the dash to lock the car
4 Press and hold the door lock button on the dash, the alarm will beep
5 Keep holding the door lock button on the dash, press and hold the lock on the remote,
the alarm will beep
Repeat (5) for the other remotes,
6 leave the door lock button on the dash, the alarm will beep, switch ignition off
2helpful
Alarm goes off when trying to remote start my o 06 malibu was up!!!
i hav same problem chaged battery noticed battery holder was loose so i soldered it very carefully everything works fine xcept remote start alarm just goes off like when you push the panic button not sure what happened dont think i shorted out the circuit board in the fob if engine light is on this car wont start via remote these remotes must b progamed by dealer or pro shop prob using what they call a tech II computer to remote start you hav to press lock button 1st even if car is already locked i figured this out pess and hold lock button then press start alarm dont ring and the car starts.
4helpful
2answers
2007 Saturn Aura; when trying remote start horn beeps three times but doesn't start. I've replaced battery. Other functions work fine - door locks, trunk opens, alarm arms. Other key fob works fine.
press the lock button on the remote then press the remote start button. if this does not work check remote start status using steering wheel buttons
1helpful
2000 Toyota Rav4, just purchased. Has a two button Toyota FOB for door locks, alarm and remote starter? . The vehicle has a OEM Toyota remote starter installed but I don't know what combination of buttons...
My ex girlfriend had a factory installed honda remote strt on her vehicle. It was activated by hitting the lock button two times in succession. Some vehicles use a combination of the lock-unlock buttons. try using some combinations on the remote, many "oem" remote starts are installed by aftermarket installers so who knows what they did as a start function, it could also have been changed by the previous owner.
2002 Montana power door locks
u r on ur child lock u deactivat ur child lock .
2answers
1999 pontiac montana keyless entry
If this is a Factory installed System You will have to get it from the Dealer. If not, You need to find out Who the Manufacturer is of the System and Contact them for a Replacement.
Remote key less opener doesn't work/can't disalarm and drive
Stand in front of the Van and press and hold both the lock and unlock buttons for 10 seconds.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
