Question about Fisher PC-25S80 25" TV
Picture slowly fades,then comes back and repeats
1985 Fisher studio standard digital control high fidelity console,back then the best tv money could buy,best tv ever,best picture,and stereo sound,ill never buy a new one that last like this,//////////can i get this repaired? is the picture tube going out?what would the estimated cost be? thanks
  • stacy_178 May 23, 2009
    thank you,i havent had a chance to take the back off yet,but im going to keep this info
    Problem Solver:
  • 7 Answers
Stacy,
Sounds to me like there is bad solder somewhere on the filament supply circuit. Do you know what a cold solder joint looks like? It is a solder joint that is not making a good mechanical or electrical connection. When you lose that connection the filament inside the tube slowly stops heating the electron guns and the picture will fade away. When the connection comes back the video will come back.
Might be worth it to take the back off and check out the little board that is connected to the end of the tube. The problem is either there or on the power supply.
Shouldn't be a problem for a repair tech. I would not spend very much money though.
Posted on May 22, 2009
I bought a studio standard by fisher tape deck and it makes a buzzing sound and it wont play tapes what do i do
Take it back, it's broken!
Buzzing can be a fault on leads connected to it, but 'won't play tapes is terminal unless you ant to spend money on repair. Tapes are an antique of the past superseded by CD, and now MP3 digital.
Nov 16, 2016 | Audio Players & Recorders
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Fisher floor model studio standard high fidelity tv
i think your tuner is broken i had similar problem with a panasonic tv and the dealer said it was the tuner that was broken the tv shuts off and i had to turn off and on to gettit to work.
Aug 30, 2008 | Televison & Video
Picture images getting dimmer or fading like no backlights
Hiii...
I'm not quietly sure ...have you check the GK Board looks at B+(135 V) check all 5V regulated..check all High voltage capacitor if there's have low ESR or dry cap...
# send me an e-mail to : be_cek@yahoo.com for compplete copy of the schematic...
Thank's
[Vrya]
Mar 04, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Durabrand 27" TV
the problem, lies on the flyback ,, on the flyback there two adjustment, the screen and focus that was writtten , adjust only the screen slowly untill screen of your tv back to normal.....fading because over saturation of voltage, adjust the screen trimmer counterclocwise....
Feb 23, 2008 | Durabrand DWT1905 TV
Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Jul 14, 2007 | Sanyo HT30744 TV
Sony TV - No picture
If the picture slowly fades on, the you may have a weak picture tube or a loose solder connection in the filiament circuit. If the picture flashes on then you may have a problem with the High Voltage/Horizontal circuit. This type of problem could be caused by a loose solder connection on the horizontal driver transformer. There are several other problems that could cause this type of problem. Stargazer
May 26, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My TV is fading out...
near the line output transformer there is a resistor which is high in value or open circuit this causes a high contrast effect needs a tech
Mar 20, 2007 | Bush WS6671 28" TV
Picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Oct 11, 2006 | Mitsubishi CS-40507 40" TV
Fisher PC-25S80 25" TV Logo
130 people viewed this question
Top Fisher Televison & Video Experts
matt martin
matt martin
Mike
romy sibug
romy sibug
Are you a Fisher Televison and Video Expert? Answer questions, earn points and help others
